查看: 491|回复: 14
How do you make your “sleepers” more comfortable?
 楼主| 发表于 2019-6-19 01:22:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Mattress change? Bed sheet change?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-19 04:37:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Replace stick mattress with thick memory foam one. I place sound dampening materials throughout creaky, squeaky cracks and crevices of the interior, remove the top bunk mattress and use the flat surface to crawl up and have a place to do my pushups. I also buy those window screens that you cut to fit your truck to enjoy a nice breeze without letting flies in on a nice day and save fuel. I use a dim orange or reddish interior light instead of bright white or bluish lights after shutting down to help activate melatonin and stimulate the body’s circadian rhythm to sleep deeper. I also use a small ionizer/air purifier (helps keep the air fresher), place scented dryer sheets in the cabinets and drawers to keep it fresh, vacuum often, use all natural orange or lemon cleaner to clean the floor and interior occasionally, turn off the rear speakers and adjust the EQ on the stereo to be more flat and only work up front to prevent noise pollution (you’d be surprised how much electromagnetic chaos can make you feel stressed or tired while driving due to high pressure levels from loud frequencies). With lower back issues from sleeping on most mattresses, I sometimes sleep with a body pillow between my knees which really helps. Also consider keeping a real chair folded up in the truck to sit up straight in while shutdown but not asleep, instead of sitting up on the soft mattress of your bed, which is terrible for your posture as it causes compression on the lower back, and after hours in a sitting position driving, the lower back needs to stretch. Also stretch your entire body every morning, and use your pre-trip and going into the truck stop to groom as an opportunity to stretch and get woken up good before heading out. I see too many drivers just wake up, rubbing their eyes and just taking off without pre-tripping or waking up good. Also consider having shoes or boots you can easily take on and off and leave them in the driver floor board instead of treading dirt in the sleeper and give your steppers a rest. I keep a mat under the driver seat and at the foot of the bed to help keep mud and dirt down. I also keep an open bottle of water in a cup holder to humidify the air, as the A/C and heater dries it out. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-6-19 08:42:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m going to read that tonight to help me fall asleep..jk... going to try the colored lights, I didn’t know that","replyToPid":0}
 楼主| 发表于 2019-6-20 01:47:20 来自手机 | 显示全部楼层
497499 发表于 2019-06-18 20:37:15 Replace stick mattress with thick memory foam one. I place sound dampening materials throughout creaky, squeaky cracks and crevices of the interior, remove the top bunk mattress and use the flat surface to crawl up and have a place to do my pushups. I also buy those window screens that you cut to fit your truck to enjoy a nice breeze without letting flies in on a nice day and save fuel. I use a dim orange or reddish interior light instead of bright white or bluish lights after shutting down to help activate melatonin and stimulate the body’s circadian rhythm to sleep deeper. I also use a small ionizer/air purifier (helps keep the air fresher), place scented dryer sheets in the cabinets and drawers to keep it fresh, vacuum often, use all natural orange or lemon cleaner to clean the floor and interior occasionally, turn off the rear speakers and adjust the EQ on the stereo to be more flat and only work up front to prevent noise pollution (you’d be surprised how much electromagnetic chaos can make you feel stressed or tired while driving due to high pressure levels from loud frequencies). With lower back issues from sleeping on most mattresses, I sometimes sleep with a body pillow between my knees which really helps. Also consider keeping a real chair folded up in the truck to sit up straight in while shutdown but not asleep, instead of sitting up on the soft mattress of your bed, which is terrible for your posture as it causes compression on the lower back, and after hours in a sitting position driving, the lower back needs to stretch. Also stretch your entire body every morning, and use your pre-trip and going into the truck stop to groom as an opportunity to stretch and get woken up good before heading out. I see too many drivers just wake up, rubbing their eyes and just taking off without pre-tripping or waking up good. Also consider having shoes or boots you can easily take on and off and leave them in the driver floor board instead of treading dirt in the sleeper and give your steppers a rest. I keep a mat under the driver seat and at the foot of the bed to help keep mud and dirt down. I also keep an open bottle of water in a cup holder to humidify the air, as the A/C and heater dries it out.
","text":"Well said! Thanks!","replyToPid":124405}
发表于 2019-6-19 08:27:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow Scott! What a book. Good job ","replyToPid":0}
发表于 2019-6-19 02:17:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Serta foam mattress topper","replyToPid":0}
发表于 2019-6-19 15:30:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"i clean my truck with mint cleaner, like Dr. Bronner's every day because it opens up my sinuses better than allergy meds. Extra pillows. Mattress pads. I keep my bed free of clutter. It's a sleep space not a storage spot. No bags and such.","replyToPid":0}
发表于 2019-6-19 04:48:25 来自手机 | 显示全部楼层
654793 发表于 2019-06-18 18:17:55 Serta foam mattress topper
","text":"100 👍","replyToPid":124261}
发表于 2019-6-19 04:51:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"What part of ca u from?","replyToPid":124424}
发表于 2019-6-19 04:54:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"L.A.","replyToPid":0}
发表于 2019-6-19 04:56:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I Grew up in Echo Park","replyToPid":124429}
GMT+8, 2026-4-17 21:42 , Processed in 0.100537 second(s), 24 queries .
