查看: 379|回复: 21
Great company to work for
 楼主| 发表于 2019-6-18 10:12:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello everyone I'm new to the trucking business and I'm looking for a new trucking company that will take me any info would be great","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-18 13:01:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"prime is no good. typically all major carriers are trash"}
回复 支持 7 反对 0
发表于 2019-6-18 13:43:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Suggestion\nYou're new to the industry. What skills have you learned and are licensed to legally perform as a service within the industrry? What exactly is you goal or what is it you want to accomplish? Do you want to work as a company professional or an owner op? What type of freight do you want to haul? If you know what type of freight you want to haul that would narrow down the company of choice. You might want to consider having endorsements on your license this specializes and will increase your worth in the marketplace.. Consider personal research, talk to drivers that actually work for companies you're considering, and speak to recruiters/have a list of direct questions ready when you do.\n\nGood starter mega companies;\nDry van : Werner / new will train / check Crete they may take you\nFlat bet: Melton / new will train \nRefer : Prime = Jbs Carriers\nI use to work for Jbs carriers they are a meat company with less than 700 trucks at the time I was there. They have real guaranteed pay. That actually pays. They have solid good equipment and repairs are done on the spot when needed.","replyToPid":0}
发表于 2019-6-18 10:35:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Prime Inc Springfield, Missouri","replyToPid":0}
发表于 2019-6-18 10:36:06 来自手机 | 显示全部楼层
597174 发表于 2019-06-18 02:35:52 Prime Inc Springfield, Missouri
","text":"877-866-0001","replyToPid":123735}
 楼主| 发表于 2019-6-19 10:29:58 来自手机 | 显示全部楼层
435615 发表于 2019-06-18 05:43:09 Suggestion\nYou're new to the industry. What skills have you learned and are licensed to legally perform as a service within the industrry? What exactly is you goal or what is it you want to accomplish? Do you want to work as a company professional or an owner op? What type of freight do you want to haul? If you know what type of freight you want to haul that would narrow down the company of choice. You might want to consider having endorsements on your license this specializes and will increase your worth in the marketplace.. Consider personal research, talk to drivers that actually work for companies you're considering, and speak to recruiters/have a list of direct questions ready when you do.\n\nGood starter mega companies;\nDry van : Werner / new will train / check Crete they may take you\nFlat bet: Melton / new will train \nRefer : Prime = Jbs Carriers\nI use to work for Jbs carriers they are a meat company with less than 700 trucks at the time I was there. They have real guaranteed pay. That actually pays. They have solid good equipment and repairs are done on the spot when needed.
","text":"great info thank you I will look into a few and ask around","replyToPid":123814}
发表于 2019-6-19 01:03:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any company will pretty much take you in Swift ,Werner, Knight those are pretty good starter companies but you just got to start from the bottom. They are good starter companies. Some companies are stricter than others and as far as drug test .May trucking will take anyone. But the good companies require minimal of a year to two years of experience that's why we need to start with the bigger companies","replyToPid":0}
发表于 2019-6-18 12:31:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Knight Refrigerated will do you good as a starter company ","replyToPid":0}
发表于 2019-6-18 11:31:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Melton Truck Lines. hmu I'll get you contact with my recruiter","replyToPid":0}
发表于 2019-6-18 13:44:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Suggestion\nYou're new to the industry. What skills have you learned and are licensed to legally perform as a service within the industry? What exactly is you goal or what is it you want to accomplish? Do you want to work as a company professional or an owner op? What type of freight do you want to haul? If you know what type of freight you want to haul that would narrow down the company of choice. You might want to consider having endorsements on your license this specializes and will increase your worth in the marketplace.. Consider personal research, talk to drivers that actually work for companies you're considering, and speak to recruiters/have a list of direct questions ready when you do.\n\nGood starter mega companies;\nDry van : Werner / new will train / check Crete they may take you\nFlat bet: Melton / new will train \nRefer : Prime = Jbs Carriers\nI use to work for Jbs carriers they are a meat company with less than 700 trucks at the time I was there. No to big, a mid range carrier. They have real guaranteed pay. That actually pays. They have solid good equipment and repairs are done on the spot when needed.","replyToPid":0}
发表于 2019-6-18 22:52:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"flatbed?","replyToPid":0}
发表于 2019-6-18 23:18:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"grmi","replyToPid":0}
GMT+8, 2026-4-18 08:15 , Processed in 0.104441 second(s), 24 queries .
