查看: 882|回复: 29
🤦🏻‍♀️🤦🏻‍♀️Weight station
 楼主| 发表于 2019-5-12 10:52:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can someone please tell me what I do wen I’m getting close to a weight station and says. Truck must Enter and my Transborder turn on the green light? Please ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-12 11:52:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"go drive a Honda if you haven't figured out the job details... so many have no common sense and or can't think for themselves","replyToPid":0}
回复 支持 0 反对 10
发表于 2019-5-12 11:12:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Enter the weigh station. If you go by even if the prepass is green DOT still may chase you down. Just do what the sign says and your day will be easier.","replyToPid":32325}
回复 支持 2 反对 5
发表于 2019-5-12 13:38:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"unless it's specifically a sign that is triggered by you passing it and says you must enter, I would listen to what the transponder says.","replyToPid":0}
回复 支持 4 反对 2
发表于 2019-5-12 11:58:08 来自手机 | 显示全部楼层
回复 支持 2 反对 4
发表于 2019-5-12 11:48:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"No sir. You keep going. If that happens (which would be very rare) the driver will have to show the officer the blinking green light on the transponder that gave the driver the ok to bypass. Read the signs.","replyToPid":0}
回复 支持 4 反对 2
发表于 2019-5-12 11:44:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just keep going. There should have been a sign before the weight station that lets you know to go by what the transponder says.","replyToPid":0}
回复 支持 4 反对 2
发表于 2019-5-12 22:07:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Green light means go regardless of what the sign says. ","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-5-12 18:30:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Usually they have a sign nearby that says “follow in cab signal” which means your little light has the final say. If by some miracle they do pull you over, you just show them the green light and they will let you go. \nThe weigh station in North Platte, NE does this to me all the time and I’ve never had an issue 🙂","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-5-12 23:08:18 来自手机 | 显示全部楼层
103619 发表于 2019-05-12 03:52:49 go drive a Honda if you haven't figured out the job details... so many have no common sense and or can't think for themselves
","text":"Everyone was a rookie once ","replyToPid":32379}
回复 支持 4 反对 1
发表于 2019-5-12 12:25:45 来自手机 | 显示全部楼层
292556 发表于 2019-05-12 03:44:03 Just keep going. There should have been a sign before the weight station that lets you know to go by what the transponder says.
","text":"theres typically a sign that says follow lighted messages.","replyToPid":32371}
回复 支持 3 反对 2
 楼主| 发表于 2019-5-12 11:09:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should I keep going or enter?","replyToPid":32325}
回复 支持 0 反对 3
发表于 2019-5-12 11:13:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why are you commenting when all you do on here is complain. Go whine on Facebook.","replyToPid":32325}
回复 支持 0 反对 4
发表于 2019-5-12 11:45:16 来自手机 | 显示全部楼层
666675 发表于 2019-05-12 03:09:13 Should I keep going or enter?
","text":"Keep on going","replyToPid":32340}
回复 支持 3 反对 2
GMT+8, 2026-4-16 04:00 , Processed in 0.150359 second(s), 24 queries .
