查看: 36|回复: 0
264 Rear Axle Ratio???
 楼主| 发表于 2019-1-24 12:18:57 来自手机 | 显示全部楼层 |阅读模式
{"text":" have a friend buying his first truck.He has found a Great starter truck that is priced right and in really good condition, 14L Det. It has a ddirect 10spd with a 264 rear axle ratio. \n\nNow, I have owned many trucks in the last 20 yrs, but have no experience with this axle ratio. Everything I have owned or currently own has been geared from 3.42 to 3.90. I assume the final gear in the transmission is lower than normal to offset this type rear end ratio??? Anyone have any experience, thoughts, advice on a 264 rear ratio ??\n\nI did some research online, and found that most of the older Walmart trucks were setup this way. \n\nAdvice ???","pics":"[]","canComment":true}
GMT+8, 2026-2-4 04:59 , Processed in 0.084617 second(s), 23 queries .
