查看: 190|回复: 8
Had a blowout on all trailer tires while in motion. The air line connects to the break chamber broke off
 楼主| 发表于 2019-6-15 22:47:58 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":1920.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
发表于 2019-6-16 00:25:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks Like you slid the tires and blew them","replyToPid":0}
 楼主| 发表于 2019-6-16 06:35:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"TA technician advised me to replace the broken part with cooper instead of plastic","replyToPid":121425}
发表于 2019-6-16 02:47:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dayam! Scary moment or two!","replyToPid":0}
 楼主| 发表于 2019-6-17 02:07:08 来自手机 | 显示全部楼层
710313 发表于 2019-06-16 02:19:18 I bet you kicked up some debris in roadway, it broke air chamber, brakes locked down, blew those two tires... you tried limping to truck stop, blowing the other two on the way....  just an educated guess based on the pics you provided....
","text":"The tires were blown when the brakes locked, when I pulled over on the shoulder I noticed the rest had bad flat spots so I decided to drag it to TA 1/2 a mile away. This happened on I-85 N in GA right after the road construction zone going to SC.","replyToPid":121829}
发表于 2019-6-16 22:00:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Say whaaaaat? How does that happen?","replyToPid":0}
发表于 2019-6-16 12:41:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"No way that happened from one break chamber line breaking!!! Be honest 😏","replyToPid":0}
 楼主| 发表于 2019-6-16 07:07:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"When the air line broke, the trailer tires were automatically engaged and at 70mph trying to pull over to the shoulder blew them","replyToPid":0}
 楼主| 发表于 2019-6-16 01:16:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wabash used a cheap plastic connector instead of cooper","replyToPid":0}
GMT+8, 2026-2-8 10:00 , Processed in 0.064112 second(s), 24 queries .
