查看: 231|回复: 7
Blocked the left lane for over 25 minutes lol
 楼主| 发表于 2019-6-15 09:12:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Couple cars were honking and flashing hi beams but this guy didnt care. Eventually the tanker let him pass after 25 miles or so lol","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-6-15 10:07:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"The tanker driver was the biggest diçk by the sounds of it ","replyToPid":0}
回复 支持 5 反对 3
 楼主| 发表于 2019-6-15 13:37:06 来自手机 | 显示全部楼层
607385 发表于 2019-06-15 01:59:33 uhhhhhhhhh that grinds my gears... u see him trying to pass just slow down a quick sec.. some drivers today!!
","text":"Truck on the left shouldn't attempt to take over. they were practically going the exact same speed. More his fault than the tanker imo","replyToPid":121108}
回复 支持 3 反对 4
发表于 2019-6-15 18:58:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I got my cruise control set and I run up on you that means im moving faster than you. Let me pass or yes I will hold up traffic for as long as it takes....... just my 2 cents","replyToPid":0}
回复 支持 3 反对 3
发表于 2019-7-1 08:15:45 来自手机 | 显示全部楼层
716996 发表于 2019-06-15 02:07:57 The tanker driver was the biggest diçk by the sounds of it
","text":"had a guy do that to me today.  I catch up to him, try and pass him, he starts going a little faster. I go back into land behind them and start catching up to him again. I attempt another pass, same shit. at that point I just sat in the left lane for 15 minutes trying to pass him at about 2 ft a minute. he finally let me get ahead. just do speed right past me 2 minutes later. I'm governed to 65 and was pedal to metal the whole time. he could go much faster. \n\nsome people enjoy being d!cks","replyToPid":121121}
回复 支持 2 反对 3
发表于 2019-6-15 23:30:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"im in California so we dont run fast but i usually run a lil faster than others.i dont hold up traffic.when i come out to pass i make sure its clear of cops and hammer is down im around them in seconds..i hate seeing some one pass someone doing 60 and they pass doing 61.5.it holds me up also.crank it up pass get some distance then go back to your normal speed","replyToPid":0}
回复 支持 2 反对 3
发表于 2019-6-15 10:28:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"What a dįćkhêâd","replyToPid":0}
回复 支持 1 反对 3
发表于 2019-6-17 22:09:06 来自手机 | 显示全部楼层
704132 发表于 2019-06-15 15:30:22 im in California so we dont run fast but i usually run a lil faster than others.i dont hold up traffic.when i come out to pass i make sure its clear of cops and hammer is down im around them in seconds..i hate seeing some one pass someone doing 60 and they pass doing 61.5.it holds me up also.crank it up pass get some distance then go back to your normal speed
","text":"Believe me if I could do 80mph I'd fly by em. Only problem is mt truck only goes 65mph.","replyToPid":121304}
回复 支持 1 反对 3
GMT+8, 2026-4-21 08:07 , Processed in 0.124742 second(s), 24 queries .
