查看: 344|回复: 17
what can I use to keep my fridge door shut inside the truck??????
 楼主| 发表于 2019-6-15 00:57:08 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-6-15 02:04:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"“Safety 1st Multi Purpose Appliance Lock”\nTrust me, it’s the best solution. \nIt’s a baby proofing thing, you can get it at Walmart 😁\nThe packaging even shows it on a mini fridge"}
回复 支持 6 反对 0
发表于 2019-6-15 00:59:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never go wrong with a bungee ","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-6-15 01:06:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"velcro","replyToPid":0}
发表于 2019-6-15 12:47:30 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"a welders 90⁰ magnet... Lowe's or home depot like $20\nedit. might not find em in those stores anymore \n\nhttps://www.google.com/search?q=inside+outside+magnet&tbm=isch&ved=2ahUKEwj0otfO1-riAhVRPawKHZeZBC0Q2-cCegQIABAC&oq=inside+outside+magnet&gs_l=mobile-gws-wiz-img.3...29637.33681..34155...0.0..1.202.3700.0j22j1......0....1.......0..0j0i67j0i13.A2V5w-YeoHI&ei=pHgEXfTABdH6sAWXs5LoAg&bih=724&biw=412&prmd=simvn#imgrc=kNQyI7eYlZ6B8M"}
发表于 2019-6-15 02:14:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Walmart has wide velcro.i bought the big roll for 20.00 it's like 10ft.1st you cut a strip like 4-6in then cut one half of one strip and don't peel off the sticky part of the solid piece or if you do put something on it.","replyToPid":0}
发表于 2019-6-15 01:06:44 来自手机 | 显示全部楼层
635598 发表于 2019-06-14 16:59:09 Never go wrong with a bungee
","text":"thats what i use","replyToPid":120633}
发表于 2019-6-15 01:08:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"When in doubt BUNGEE ","replyToPid":120636}
发表于 2019-6-15 01:06:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"My fridge is held down by ratchet straps. I use bungies from side to side to hold the doors shut.","replyToPid":0}
发表于 2019-6-15 01:09:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Second the bungee","replyToPid":0}
发表于 2019-6-15 01:10:38 来自手机 | 显示全部楼层
75936 发表于 2019-06-14 17:06:53 My fridge is held down by ratchet straps. I use bungies from side to side to hold the doors shut.
","text":"that is my exact setup","replyToPid":120637}
发表于 2019-6-15 01:21:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Jedi mind tricks 😺","replyToPid":0}
GMT+8, 2026-4-18 07:36 , Processed in 0.109673 second(s), 24 queries .
