查看: 171|回复: 0
2004 freightliner M2 Mercedes motor going into safety mode!!
 楼主| 发表于 2019-1-24 10:50:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello everyone I have a 2004 Freightliner M2 box truck with the Mercedes motor and manual transmission. Truck starts up fine runs good for about 30 to 40 minutes depending on the temperature outside seems to run longer when it’s colder out then all the sudden goes into a safety mode the engine start stuttering like it’s missing check engine light comes on and I lose all response from the gas pedal only way to move the truck is to put it in first gear and let it coast on its own I’ve already checked the fuel filter and replaced it also replaced the engine fuse box and the roller sensor behind the gas pedal. Has anyone come across this issue before? ","pics":"[]","canComment":true}
GMT+8, 2026-4-17 05:54 , Processed in 0.077170 second(s), 24 queries .
