查看: 462|回复: 12
I’ve been having issues i need some help with my truck
 楼主| 发表于 2019-5-9 15:19:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I get to my truck looking around it like usual pop the hood. Truck is low on coolant. Driving my truck about 72, 73 i don’t like to speed more then that. Light comes on low coolant. I got out pop the hood its low , as  i release the pressure off the coolant cap the coolant goes back up. Hop in start rolling twenty min later same thing. I get too my destination turn my truck offf , wake up in the morning same thing low coolant. Wtf is the problem any one ever had this issue? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-10 01:00:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do the blowby test. You may have a blown head gasket. If you don’t know the test, look it up on YouTube. You’ll need a bottle of water. ","replyToPid":0}
发表于 2019-5-11 21:38:32 来自手机 | 显示全部楼层
654793 发表于 2019-05-09 13:10:27 My isx was doing the same thing and it was the float inside the coolant reservoir... replaced the whole reservoir and no more issues. I just unplugged the sensor until I was able to get it fixed and made sure to check to level everyday
","text":"I had the same issue, same engine. You have a small leak that gets bad when the coolant pressure is high, like when climbing hills. It may take a bit to find, but have a good mechanic pressurize your system to find the leak.","replyToPid":30557}
发表于 2019-5-9 23:12:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"text me for more advice 413 829 4849","replyToPid":0}
发表于 2019-5-9 20:57:29 来自手机 | 显示全部楼层
651403 发表于 2019-05-09 07:51:08 I know am still losing coolant to the point my sensor shuts my truck off my truck if i dont stop to check it
","text":"Could be a bad coolant level sensor does your coolant rise to normal after turning off the engine?","replyToPid":30386}
发表于 2019-5-9 23:48:50 来自手机 | 显示全部楼层
651403 发表于 2019-05-09 07:30:04 No burning at all no smoke no smell  but i fixed all leaks the only thing i see it do when am parked like little drops on the ground from pressure hose that leaks collant by it self when its too much pressure
","text":"Are you sure your not over filling the resevoir that pressure isnt normal unless your overheating the engine or you have to much coolant what temp does it say when light comes on and engine shuts off","replyToPid":30378}
 楼主| 发表于 2019-5-9 15:30:04 来自手机 | 显示全部楼层
681714 发表于 2019-05-09 07:23:36 Do you smell any coolant burning in the engine bay when the truck has been running? Is there any White smoke coming from your exhaust when revving? Coolant can only leak or burn. Otherwise it just recirculates. The level in the resevoir tank varies at times.
","text":"No burning at all no smoke no smell  but i fixed all leaks the only thing i see it do when am parked like little drops on the ground from pressure hose that leaks collant by it self when its too much pressure ","replyToPid":30377}
 楼主| 发表于 2019-5-9 15:51:08 来自手机 | 显示全部楼层
681714 发表于 2019-05-09 07:33:44 That's called a cold water leak. It's normal and will stop once the coolant is warm.
","text":"I know am still losing coolant to the point my sensor shuts my truck off my truck if i dont stop to check it ","replyToPid":30381}
 楼主| 发表于 2019-5-9 15:54:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"D13 ","replyToPid":30387}
发表于 2019-5-9 21:10:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"My isx was doing the same thing and it was the float inside the coolant reservoir... replaced the whole reservoir and no more issues. I just unplugged the sensor until I was able to get it fixed and made sure to check to level everyday ","replyToPid":0}
发表于 2019-5-10 00:48:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try this let your engine cool down for a while  if it shows low coolant fill it it up to the full line start your engine let it warm up in idle dont run it leave it on long enough so the thermostat opens up if your coolant level drops then keep adding coolant until its full do this while the engine is running if it doesnt fill you should have a very obvious leak somewhere or coolant in your oil","replyToPid":0}
发表于 2019-5-10 00:51:04 来自手机 | 显示全部楼层
","text":"Maybe air in your coolant system check resevoir cap and gasket or craks on the resevoir tank ","replyToPid":30378}
GMT+8, 2026-4-15 12:10 , Processed in 0.074998 second(s), 24 queries .
