查看: 1643|回复: 20
Company lied to get me to sign on.
 楼主| 发表于 2019-5-6 21:59:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Had a good company for over 3 years USX lied about walk away L/O options, lied about a lot of things, and after I resigned from the company I was with, they decided I wasn’t eligible. But hey company is available and hey you’re already hired so?  I didn’t have much choice unemployment or this crappie company... not happy at all. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":620.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-5-7 00:07:13 来自手机 | 显示全部楼层
635207 发表于 2019-05-06 14:49:28 People often see the brand name mega carriers first so it's easy to look into 10 of them before anyone else, but in all actuality those small carriers you never heard of are a lot better. But they don't have the advertising budget to get noticed.
","text":"100% true, smaller companies are way better ","replyToPid":28346}
回复 支持 8 反对 2
发表于 2019-5-6 22:49:28 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"People often see the brand name mega carriers first so it's easy to look into 10 of them before anyone else, but in all actuality those small carriers you never heard of are a lot better. But they don't have the advertising budget to get noticed."}
回复 支持 6 反对 2
 楼主| 发表于 2019-5-9 04:12:37 来自手机 | 显示全部楼层
681434 发表于 2019-05-08 17:03:40 Any driver with a clean MVR can walk away from any company and have another job within an hour.  If they didn’t give you what they promised, dump ‘em and start orientation somewhere else on Monday.
","text":"It’s called employment stability, and affects you’re credit rating. Company jumping is never a good idea clean mvr or not","replyToPid":29724}
回复 支持 4 反对 1
发表于 2019-5-6 23:29:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"In the future get agreements in writing beforehand I'm like you learned the hard way....","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-7-10 08:37:27 来自手机 | 显示全部楼层
599477 发表于 2019-05-06 18:56:53 Aren’t the smaller companies with the horror stories of randomly shutting down and not paying drivers for months, though?
","text":"The reason they make the news is because it’s uncommon.\n\nStill, do your research first.  How long have they been in business?  What’s their safety record?  Are they financially stable?  Is the owner healthy?  \nIf you can, talk to their drivers.\n\n","replyToPid":28453}
发表于 2019-5-7 02:56:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Aren’t the smaller companies with the horror stories of randomly shutting down and not paying drivers for months, though?","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-5-6 23:31:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go back.","replyToPid":0}
回复 支持 1 反对 3
发表于 2019-5-10 05:46:54 来自手机 | 显示全部楼层
27391 发表于 2019-05-08 20:12:37 It’s called employment stability, and affects you’re credit rating. Company jumping is never a good idea clean mvr or not
","text":"I’m not recommending excessive company jumping.  Make the right decision the next time, but if someone clearly lied to you, right down to changing the type of job ( lease to company driver) a quick jump (preferably during orientation...but after if necessary) is not inappropriate.  Just stay at the next one for a minimum of a year...and as far as your credit rating, pay on time and you’re fine.","replyToPid":29893}
发表于 2019-5-9 01:03:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any driver with a clean MVR can walk away from any company and have another job within an hour.  If they didn’t give you what they promised, dump ‘em and start orientation somewhere else on Monday.","replyToPid":0}
发表于 2019-5-7 09:57:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got in2 a shouting match wit 1 of 'em @ tunkabunk, PA P&G.","replyToPid":0}
发表于 2019-5-7 02:17:44 来自手机 | 显示全部楼层
","text":"100% accurate","replyToPid":28346}
发表于 2019-5-7 04:06:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is there a way to pm on here?","replyToPid":0}
发表于 2019-5-7 04:53:11 来自手机 | 显示全部楼层
449144 发表于 2019-05-06 20:06:38 Is there a way to pm on here?
","text":"I don't think there is","replyToPid":28468}
GMT+8, 2026-4-18 01:02 , Processed in 0.110762 second(s), 24 queries .
