查看: 112|回复: 1
What chain length do most of you use?
 楼主| 发表于 2019-5-6 04:46:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"This is for a 48' flat running general freight and steel. 20 or 25ft?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-6 06:50:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"It depends what you will be hauling.  I personally have 4 4' with hooks on one end ,4 6' hooks on one end 8 12' hooks on both ends 8 20' hooks on both ends and 2 each 8 n 10' and about 16 ratchet binders. I haul everything.  Mostly equipment tho\n\nI personally wouldn't buy 25' at all unless you want to cut them into shorter ones. ","replyToPid":0}
GMT+8, 2026-4-17 23:25 , Processed in 0.099692 second(s), 23 queries .
