查看: 218|回复: 3
What are the most stable carriers out there?
 楼主| 发表于 2019-5-5 03:05:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"I mean, alot of companies are opening and closing. Which one is the most stable?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-5 03:32:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"look into tca's list top 20 best feet fleets to drive for. there's a good reason many of the companies that are on that list are are good to drive for","replyToPid":0}
发表于 2019-5-5 05:46:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"they are called the best companies because they are the ones that can bend you over and slam it to you","replyToPid":0}
发表于 2019-5-5 09:29:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"**** that noise I'll go small carrier any day","replyToPid":0}
GMT+8, 2026-4-17 07:30 , Processed in 0.087671 second(s), 23 queries .
