查看: 598|回复: 33
what to do
 楼主| 发表于 2019-5-4 21:47:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"what do I do if I'm overweight after the shipper! I'm a hotshot","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-4 22:26:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d really like to be sarcastic to your comment sran. But someone rookie might believe California closes on the weekend. ","replyToPid":0}
发表于 2019-5-4 22:01:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"slip your tandems","replyToPid":0}
回复 支持 0 反对 3
发表于 2019-5-4 22:01:42 来自手机 | 显示全部楼层
654793 发表于 2019-05-04 13:55:14 Gotta go back and remove items from the load til ur legal
","text":"no","replyToPid":27412}
发表于 2019-5-4 23:42:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"And if your rolling through Oklahoma or Texas those weigh stations stay open even during tornados. If the tornado is over weight coming through it will put it out of service. Lol","replyToPid":0}
发表于 2019-5-4 22:32:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh that place isn’t in my map book. Lol","replyToPid":0}
发表于 2019-5-5 09:33:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go back and repack if you can’t slip the 5th wheel and tandems to balance. If you’re under 45 in a dry van sometimes this works and sometimes you just have to **** up a repack and enjoy it","replyToPid":0}
发表于 2019-5-5 09:19:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"If no option and you don’t like to go around scales then get overweight permits for one trip all flatbed drivers now how to do it ","replyToPid":0}
发表于 2019-5-5 09:11:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a dump ","replyToPid":0}
发表于 2019-5-5 01:43:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Burn off fuel. Or get on the cb and find a driver that will one either move freight to their trailer to get around scale or help you with directions around scale. I am a truck driver ie. it should be a given you have a cb, right?","replyToPid":27480}
发表于 2019-5-5 00:16:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"He said overweight. Not over on an axle. What’s your solution. ","replyToPid":0}
发表于 2019-5-4 21:55:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gotta go back and remove items from the load til ur legal","replyToPid":0}
发表于 2019-5-4 22:06:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"No to both. Need more info than just over weight. What are your axle weights?","replyToPid":0}
发表于 2019-5-4 22:23:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its weekend  ...JUST RUN if in CA \nScales wont open ","replyToPid":0}
发表于 2019-5-4 22:31:02 来自手机 | 显示全部楼层
{"replyToPid":27422,"replyTo":"
163694 发表于 2019-05-04 14:26:42 I’d really like to be sarcastic to your comment sran. But someone rookie might believe California closes on the weekend.
","text":"Yeah but u know i was talking about 🇨🇦 😂"}
发表于 2019-5-4 22:32:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"you need to eat less.","replyToPid":0}
GMT+8, 2026-4-17 23:06 , Processed in 0.152775 second(s), 24 queries .
