查看: 485|回复: 10
 楼主| 发表于 2019-5-3 11:49:21 来自手机 | 显示全部楼层 |阅读模式
{"text":".","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2019-5-3 16:15:25 来自手机 | 显示全部楼层
322418 发表于 2019-05-03 06:49:45 It might be at the dot discretion on what’s allowed for personal conveyance. I was told you can use it as long as you are bob tailing with no trailer behind but some say you can use it as long as your empty. Like I said I think it’s all up to what kind of mood the dot officer is in
","text":"new rules for 2019 on personal conveyance.  you absolutely can use PC with trailer or bobtail either way. if you are loaded you have to show a good reason for it, like bad weather or traffic jam between current location and nearest safe parking location.","replyToPid":26799}
发表于 2019-5-3 14:49:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"It might be at the dot discretion on what’s allowed for personal conveyance. I was told you can use it as long as you are bob tailing with no trailer behind but some say you can use it as long as your empty. Like I said I think it’s all up to what kind of mood the dot officer is in","replyToPid":0}
发表于 2019-5-19 06:08:37 来自手机 | 显示全部楼层
562244 发表于 2019-05-18 20:06:00 the problem is that by looking it up you end up with correct misinformation or incorrect information. the rules are written so vaguely that even a lawyer can misinterpret the answer.
","text":"The New Law provides you, The ability to drive past your 14 hr. HOS if a shipper or receiver runs out your Hours, To the closest safe haven, This means even if the parking is the opposite direction, And I would most definitely always let the shipper or receiver when you have about 2 hrs. left before your clock runs out, And   get all the contact information on the person you inform, As well as possibly speak to a Manager as well as your dispatch to inform them, Just keep great documentation, Just incase the DOT wants to check. To make sure you are not trying to pull a fast one to advance the load. And the company can be fined for running you out of Your HOS.","replyToPid":37757}
发表于 2019-5-4 03:24:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont mind him, hes just the resident troll here. I think he was trying to call you \"stupid\"","replyToPid":26798}
发表于 2019-5-4 23:32:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Best thing to do is look it up, You will get some of the correct answers but not all the information or Misinformation, in your situation, That way you get all the correct information.","replyToPid":0}
发表于 2019-5-3 16:39:21 来自手机 | 显示全部楼层
322418 发表于 2019-05-03 08:20:57 Ok that I didn’t know. Had no idea they changed that. That’s good tho. Only problem with it tho is how are companies paying for personal miles if you’re on mileage pay?
","text":"personal miles are just that. personal. for the most part they are used for things like driving from a consignee to the store for groceries and back to the original location. for regular use you have to start and end at the exact same facility. the only changes are now you can have a trailer, and with the eld mandate if you get into an emergency situation due to traffic and weather you can still make it to safe parking legally. but like I said before, if you are gonna use it while loaded you better have a provable and good reason for it.","replyToPid":26805}
 楼主| 发表于 2019-5-3 12:03:06 来自手机 | 显示全部楼层
625878 发表于 2019-05-03 03:59:44 If you were unloaded, you can with out a problem. As that is your time now not the companies, now if you were loading or unloading produce, you can be under (Personal Conveyance / HOS regulations produce) this will allow you to get to a truck stop.
","text":"Thank you! yes I was unloaded and used PC to find the nearest truck stop because the receiver didn’t have any overnight parking.","replyToPid":26758}
 楼主| 发表于 2019-5-3 14:36:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"What?","replyToPid":26782}
发表于 2019-5-3 16:20:57 来自手机 | 显示全部楼层
562244 发表于 2019-05-03 08:15:25 new rules for 2019 on personal conveyance.  you absolutely can use PC with trailer or bobtail either way. if you are loaded you have to show a good reason for it, like bad weather or traffic jam between current location and nearest safe parking location.
","text":"Ok that I didn’t know. Had no idea they changed that. That’s good tho. Only problem with it tho is how are companies paying for personal miles if you’re on mileage pay?","replyToPid":26802}
发表于 2019-5-19 04:06:00 来自手机 | 显示全部楼层
505487 发表于 2019-05-04 15:32:17 Best thing to do is look it up, You will get some of the correct answers but not all the information or Misinformation, in your situation, That way you get all the correct information.
","text":"the problem is that by looking it up you end up with correct misinformation or incorrect information. the rules are written so vaguely that even a lawyer can misinterpret the answer.","replyToPid":27445}
GMT+8, 2026-4-17 14:25 , Processed in 0.097817 second(s), 24 queries .
