查看: 319|回复: 27
 楼主| 发表于 2019-5-3 09:28:12 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2019-5-6 06:31:27 来自手机 | 显示全部楼层
I run an international with battery apu but ya just big battery packs
{"replyToPid":28088,"replyTo":"
366847 发表于 2019-05-05 22:20:56 I run an international with battery apu but ya just big battery packs
","text":"."}
 楼主| 发表于 2019-5-6 05:36:44 来自手机 | 显示全部楼层
A few comments back I talked about battery packs near the charging station. Those same battery packs are being installed in mass on a larger scale for different city municipalities. You can also have them for big buildings or even just for your house. They’re a front end investment but those battery packs store power to charge things or keep the lights on after a blackout or disaster. Worst case scenario they have gas powered generators to charge vehicles or power homes. As for e-trucks you’re not likely to stay in a disaster area. You’ll drive out of a blackout area to get a charge same as people that drive gas cars because when the power goes out the gas pumps don’t pump. Electric fuel pumps and all that right? Cool thing about Electric vehicles is that you can back feed your power from your vehicles battery pack to your house to power the lights. Keep in mind you have to keep enough power to drive to a charger after.
{"replyToPid":27766,"replyTo":"
366847 发表于 2019-05-05 06:18:13 A few comments back I talked about battery packs near the charging station. Those same battery packs are being installed in mass on a larger scale for different city municipalities. You can also have them for big buildings or even just for your house. They’re a front end investment but those battery packs store power to charge things or keep the lights on after a blackout or disaster. Worst case scenario they have gas powered generators to charge vehicles or power homes. As for e-trucks you’re not likely to stay in a disaster area. You’ll drive out of a blackout area to get a charge same as people that drive gas cars because when the power goes out the gas pumps don’t pump. Electric fuel pumps and all that right? Cool thing about Electric vehicles is that you can back feed your power from your vehicles battery pack to your house to power the lights. Keep in mind you have to keep enough power to drive to a charger after.
","text":"."}
 楼主| 发表于 2019-5-5 08:12:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
 楼主| 发表于 2019-5-4 21:19:03 来自手机 | 显示全部楼层
I’m not a Hydrogen fan really. I’ve had to futz with LNG trucks and H vehicles would require full service stations like days of old for the general public. People that drive off with the gasoline hose still in or cap and door open would be expensive for a high pressure hose pushing up to 10,000psi. That’s from https://www.hygen.com/how-a-renewable-hydrogen-fueling-station-works/. 700bar converts to 10,000psi. I also know from being at a company that runs a lot of LNG trucks that the clean energy pumps are always going down for some reason or another. When I talked about Nickel before it’s pure nickel that’s combined with other metals to create a desired composition for a cathode in a battery. NiMH is a complete battery.
{"replyToPid":27393,"replyTo":"
366847 发表于 2019-05-04 12:46:31 I’m not a Hydrogen fan really. I’ve had to futz with LNG trucks and H vehicles would require full service stations like days of old for the general public. People that drive off with the gasoline hose still in or cap and door open would be expensive for a high pressure hose pushing up to 10,000psi. That’s from  https://www.hygen.com/how-a-renewable-hydrogen-fueling-station-works/. 700bar converts to 10,000psi. I also know from being at a company that runs a lot of LNG trucks that the clean energy pumps are always going down for some reason or another. When I talked about Nickel before it’s pure nickel that’s combined with other metals to create a desired composition for a cathode in a battery. NiMH is a complete battery.
","text":"."}
 楼主| 发表于 2019-5-4 12:43:28 来自手机 | 显示全部楼层
Must have misread. I text and stuff while driving so I probably didn’t read it thoroughly. No if you look near that unit you may see another bank of boxes, probably off to side or curb behind a fence. A lot of big high volume charging locations have a battery storage system that they charge up when demand and prices are low to have them ready to charge an EV if rates go up. Battery installations like the one in Australia smooth out the power grids customer demand fluctuations between power plants starting up and shutting down which leads to more predictable load patterns and lower rates.
{"replyToPid":27328,"replyTo":"
366847 发表于 2019-05-04 04:41:13 Must have misread. I text and stuff while driving so I probably didn’t read it thoroughly. No if you look near that unit you may see another bank of boxes, probably off to side or curb behind a fence. A lot of big high volume charging locations have a battery storage system that they charge up when demand and prices are low to have them ready to charge an EV if rates go up. Battery installations like the one in Australia smooth out the power grids customer demand fluctuations between power plants starting up and shutting down which leads to more predictable load patterns and lower rates.
","text":"."}
 楼主| 发表于 2019-5-4 13:20:34 来自手机 | 显示全部楼层
Crapple is pushing for people to trade in old phones because they recycle the whole phone to avoid using Cobalt in their new products. I think your confusing lithium with cobalt. Lithium isn’t the material people are fussing over. It’s cobalt from the Congo mined with child labor. The cathode in an iPhones battery is 100% cobalt but that’s less of an issue since they’re pushing recycling heavily lessening their need for new cobalt.
{"replyToPid":27334,"replyTo":"
366847 发表于 2019-05-04 04:53:36 Crapple is pushing for people to trade in old phones because they recycle the whole phone to avoid using Cobalt in their new products. I think your confusing lithium with cobalt. Lithium isn’t the material people are fussing over. It’s cobalt from the Congo mined with child labor. The cathode in an iPhones battery is 100% cobalt but that’s less of an issue since they’re pushing recycling heavily lessening their need for new cobalt.
","text":"."}
 楼主| 发表于 2019-5-3 21:35:11 来自手机 | 显示全部楼层
People are constantly seeking ways to capture more electricity, more and more greenly. Volume increases and price falls. Economy of scale.
{"replyToPid":26870,"replyTo":"
366847 发表于 2019-05-03 12:37:24 People are constantly seeking ways to capture more electricity, more and more greenly. Volume increases and price falls. Economy of scale.
","text":"."}
 楼主| 发表于 2019-5-3 21:32:54 来自手机 | 显示全部楼层
发表于 2019-5-3 20:34:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bitcoin is a long term pump and dump stock on a global scale. Electricity is a physical commodity same as gasoline except it cannot be stored like gasoline in tanks. It has to be stored in huge battery pack installations which are also used to smooth out the peaks and valleys in the Electrical grids demand between start up and shutdown which results in cheaper electricity for the consumer. There are times when the Electric power plants get paid to NOT make electricity. Electric tech is only getting better with the advancement of capacitor and new batteries made of glass discovered by John B Goodenough. That’s his real name. ","replyToPid":0}
 楼主| 发表于 2019-5-3 18:22:35 来自手机 | 显示全部楼层
Takes 30mins to super charge then you leave or the machine charges you a higher rate per minute
{"replyToPid":26744,"replyTo":"
366847 发表于 2019-05-03 03:13:13 Takes 30mins to super charge then you leave or the machine charges you a higher rate per minute
","text":"."}
发表于 2019-5-3 11:13:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Takes 30mins to super charge then you leave or the machine charges you a higher rate per minute ","replyToPid":0}
发表于 2019-5-3 20:37:24 来自手机 | 显示全部楼层
664145 发表于 2019-05-03 10:22:35 Hopefully don't spike electricity rates like Bitcoin mining has.
","text":"People are constantly seeking ways to capture more electricity, more and more greenly. Volume increases and price falls. Economy of scale. ","replyToPid":26831}
发表于 2019-5-4 12:41:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Must have misread. I text and stuff while driving so I probably didn’t read it thoroughly. No if you look near that unit you may see another bank of boxes, probably off to side or curb behind a fence. A lot of big high volume charging locations have a battery storage system that they charge up when demand and prices are low to have them ready to charge an EV if rates go up. Battery installations like the one in Australia smooth out the power grids customer demand fluctuations between power plants starting up and shutting down which leads to more predictable load patterns and lower rates. ","replyToPid":0}
发表于 2019-5-4 12:53:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Crapple is pushing for people to trade in old phones because they recycle the whole phone to avoid using Cobalt in their new products. I think your confusing lithium with cobalt. Lithium isn’t the material people are fussing over. It’s cobalt from the Congo mined with child labor. The cathode in an iPhones battery is 100% cobalt but that’s less of an issue since they’re pushing recycling heavily lessening their need for new cobalt. ","replyToPid":0}
GMT+8, 2026-2-4 21:59 , Processed in 0.085470 second(s), 24 queries .
