查看: 176|回复: 5
Power Inverter
 楼主| 发表于 2019-5-3 07:46:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"PowerDrive inverter stopped working. Haven’t been to the yard to see if it’s an other issue but doubt it. Any good inverters that are 1500+ and where can I get them?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-3 09:49:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Power Drive brand us da onlay 1 u'll C @ travel centas.\nMSRP will run ya over $100.00.\n\nMechanix told me anaythang ova 300 Amps gots 2 B directlay battaray hooked.","replyToPid":0}
发表于 2019-5-3 08:01:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Does it have a fuse next to the plugs? \nInverters are at most T stops. Harbor freight has some too. ","replyToPid":0}
发表于 2019-5-4 03:34:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a Power Drive 2000 once. I woke up to a bad capacitor and smoke everywhere. Those are garbage.\n\nThe Cooper Bussmann true sine wave ones are what Kenworth installs from factory. I’m on year 4 with the one that came with my last truck. Pretty darn reliable 🙂","replyToPid":0}
发表于 2019-5-3 19:29:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Power Drive can have a circuit breaker on them. it trips if it has too much demand placed on it. Did you try unplugging it, and  pushing the reset button? Most truck stops carry inverters. I have had good luck with both Cobra and Power Drive. If it draws more than 1000 watts, always have the shop run monster cables (heavy gauge wires) to the batteries & make sure its grounded and fused properly. I have seen too many trucks burnt to the ground because of improperly installed power inverters.","replyToPid":0}
 楼主| 发表于 2019-5-4 02:02:04 来自手机 | 显示全部楼层
672031 发表于 2019-05-03 00:01:11 Does it have a fuse next to the plugs? \nInverters are at most T stops. Harbor freight has some too.
","text":"No fuse next to plugs. Also bought this one from a loves a year ago. Was in my Coronado no problems. Now in a cascadia and stopped working. ","replyToPid":26656}
GMT+8, 2026-3-21 16:51 , Processed in 0.063878 second(s), 24 queries .
