查看: 401|回复: 22
Very important message
 楼主| 发表于 2019-5-1 22:55:22 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-5-1 23:05:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like an old toaster 😂","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-5-6 08:51:53 来自手机 | 显示全部楼层
138510 发表于 2019-05-05 23:22:44 thanks for the tip driver
","text":"Not sure the price of a permit, if anay.\nTraining 2 review da Spot Lantern Fly is required B4 entering that hot zone. \n\nIt is on PSU's website.\nDriving thru, U mite B fine.\nStopping anywhurr thurr 4 ova 1/2 hour requires a DVIR fill out.","replyToPid":28114}
发表于 2019-8-2 06:53:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"seen all that last night","replyToPid":0}
发表于 2019-5-6 07:22:44 来自手机 | 显示全部楼层
664145 发表于 2019-05-05 03:51:00 SE PA between Allentown & Phil.\nNJ & DE - Since both is small coastal states.\n\nThose areas require permits & special DVIR's 4 every stop over half an hour.
","text":"thanks for the tip driver","replyToPid":27748}
 楼主| 发表于 2019-5-6 01:24:16 来自手机 | 显示全部楼层
664145 发表于 2019-05-05 03:51:48 Loox like da rot from Cazette's YT video \"Sleepless\".
","text":"😆 well that’s a dated reference ","replyToPid":27750}
发表于 2019-5-5 11:51:00 来自手机 | 显示全部楼层
138510 发表于 2019-05-05 02:03:39 yeah I read something about that. is it all if PA or just some particular towns or the whole area between.? I delivered yesterday in Harrisburg, PA drove down to VA.
","text":"SE PA between Allentown & Phil.\nNJ & DE - Since both is small coastal states.\n\nThose areas require permits & special DVIR's 4 every stop over half an hour.","replyToPid":27679}
发表于 2019-5-5 09:50:46 来自手机 | 显示全部楼层
138510 发表于 2019-05-05 01:20:38 came down from there on Monday, def bad weather still... glad to be back in the South.
","text":"Skip PA.\n\nInsect outbreak between Filthydelphia & NJ.\nNot dat U should go thurr anywayz.","replyToPid":27642}
发表于 2019-5-5 09:49:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"This Freightshaka P4 don't got no room 4 snow chains. \nSo imma outta luck 'till next month.","replyToPid":0}
发表于 2019-5-2 01:41:11 来自手机 | 显示全部楼层
599477 发表于 2019-05-01 15:39:33 Casper, Wyoming. It was 28 degrees out 🥶😭 and snowing a lot on the other side of the mountain.
","text":"Drive safe!","replyToPid":25541}
发表于 2019-5-1 23:23:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"looks like another Pixar character lol","replyToPid":0}
发表于 2019-5-1 23:05:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol","replyToPid":0}
发表于 2019-5-1 23:17:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is that a snow on a road 😱 ? Where is snowing 🌨?","replyToPid":0}
发表于 2019-5-1 23:22:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Snowed from Nevada to Wyoming yesterday in certain areas yesterday ","replyToPid":0}
 楼主| 发表于 2019-5-1 23:39:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Casper, Wyoming. It was 28 degrees out 🥶😭 and snowing a lot on the other side of the mountain. ","replyToPid":0}
 楼主| 发表于 2019-5-1 23:41:22 来自手机 | 显示全部楼层
631628 发表于 2019-05-01 15:23:51 looks like another Pixar character lol
","text":"You’re right! They’re everywhere! 😁😁😁","replyToPid":25529}
发表于 2019-5-2 03:03:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Important Nd Confidential! 🤣","replyToPid":0}
GMT+8, 2026-2-6 15:54 , Processed in 0.071583 second(s), 24 queries .
