查看: 193|回复: 7
Slow cooker recommendations?
 楼主| 发表于 2019-5-1 04:33:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"So my company won't allow a power inverter in the truck so I can only use the 12-volt inverters that only push up to 180 watts. Does anyone know a good slow cooker that uses less than that?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-1 05:35:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok I must know why they won’t let u ","replyToPid":0}
发表于 2019-5-1 07:49:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why in God’s name will they not allow an inverter?","replyToPid":0}
发表于 2019-5-1 08:26:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"What they don’t know, won’t hurt them. Just make sure you put it in your backpack when getting an inspection at your company shops. ","replyToPid":0}
发表于 2019-5-1 08:38:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"My inverter is 300 watt and connects to the 12 volt power. Should be plenty to run a crock pot. You’ll be running your truck the whole time you use it right? That long cook time will drain your batteries quickly. ","replyToPid":0}
发表于 2019-5-1 10:34:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Harbour freight has inverters of different sizes for a low cost. not sure why company don't allow one other then worried about dead batteries.  I have to have mine for my 36 inch flat screen TV my refrigerator and microwave.plus power for my laptop and tablet. a lot cheaper then eating out and a little healthier","replyToPid":0}
发表于 2019-5-1 10:35:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh Walmart has little crock pots","replyToPid":0}
发表于 2019-5-1 21:57:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"12 volt slow cooker is almost useless... took me 45 min to 90 min to cook ichabod noodles or kd","replyToPid":0}
GMT+8, 2026-4-17 19:44 , Processed in 0.091864 second(s), 23 queries .
