查看: 333|回复: 15
Over weight 🙁on a trl axle 😳
 楼主| 发表于 2019-4-30 07:04:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good evening \n\nI’m new driver and I’m back from home time 🤓 trying to get back on the road. Picked a loaded trailer and I forgot to get on cat scale thankfully weight station closed . But reminded me to check a weight and I find out that my load is over limits\nStr axles 12640lb\nDrv axles 31140lb\nTrl axles 37180lb\nWhich total 80960 lb\nFor example I have load from Illinois and heading to Indiana \nDo I need to have my axles pushed on a Illinois mark or Indiana?🧐🤨\nIs there any difference when you get on a scales and pulling out tractor brake valves but leaving trailer brakes valves in changes a weight ? 🤔","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-6 14:47:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Numbers should be burned into your brain.....( if your dry van or reefer)\n12000\n34000\n34000\n80000 max\n\n13’6","replyToPid":0}
发表于 2019-4-30 09:11:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go around all the scales......no worries.","replyToPid":0}
发表于 2019-4-30 08:44:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are over gross it doesn't matter about brakes set etc. ","replyToPid":0}
发表于 2019-5-6 02:28:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"How would that help at all if his tandems  37180 lbs.","replyToPid":0}
发表于 2019-5-4 22:44:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"IL to In shouldn’t be an issue. But for future reference. 1 gal of fuel is around 9 lbs, so you need to burn 100 gal. second Indiana only allows 12,000 on steers where most others allow 20k. Third tandems need to be slid back to bring 3000+ to drives(this depends on where load ends in trailer and other variables to determine how far back. Finally it’s Saturday, both states should be closed. ","replyToPid":0}
 楼主| 发表于 2019-4-30 10:30:59 来自手机 | 显示全部楼层
415632 发表于 2019-04-30 00:44:12 You are over gross it doesn't matter about brakes set etc.
","text":"Thank you ","replyToPid":24267}
发表于 2019-4-30 09:04:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"When you get the chance scale your truck and trailer when empty and a full tank of fuel. You should know what your maximum load can be without going overweight. Looks  like you need to slide fifth wheel back some so you’re not putting too much of the load on steers. Like most guys I have figured out where to have my fifth wheel set for most loads and just leave it there. ","replyToPid":0}
发表于 2019-5-1 11:51:01 来自手机 | 显示全部楼层
643146 发表于 2019-04-30 01:11:23 Go around all the scales......no worries.
","text":"Yup,  that's what I do 😏","replyToPid":24280}
发表于 2019-5-7 10:44:48 来自手机 | 显示全部楼层
163694 发表于 2019-05-04 14:44:05 IL to In shouldn’t be an issue. But for future reference. 1 gal of fuel is around 9 lbs, so you need to burn 100 gal. second Indiana only allows 12,000 on steers where most others allow 20k. Third tandems need to be slid back to bring 3000+ to drives(this depends on where load ends in trailer and other variables to determine how far back. Finally it’s Saturday, both states should be closed.
","text":"7.15 lbs / gallon","replyToPid":27432}
发表于 2019-5-7 10:43:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Move axles 12 holes forward. \nAs far as IL 》IN,\n\nStay on da tollway.","replyToPid":0}
 楼主| 发表于 2019-4-30 10:30:49 来自手机 | 显示全部楼层
","text":"That’s what I thought it’s how trainer tough me and I was curious ","replyToPid":24267}
 楼主| 发表于 2019-4-30 10:32:30 来自手机 | 显示全部楼层
","text":"Really 😊😁thanks do you think it’s helps?","replyToPid":24280}
 楼主| 发表于 2019-4-30 10:33:29 来自手机 | 显示全部楼层
632886 发表于 2019-04-30 01:33:49 are you in a dry van or a flat bed with 10 ft spread axles? if your using 10ft spread axles all your axle weights are good. but you are over on gross as the other driver mentioned. on 10ft spreads you can be 40,000 on trailer 34,000 on driver and depending on steer tires and wheel base and truck type and state up to tire weight rating 13,200. however if you are in Texas you can run the US highways and be over 80,000LBS.
","text":"Thank you ","replyToPid":24287}
发表于 2019-5-4 21:54:40 来自手机 | 显示全部楼层
","text":"If you are pulling a dry van, Turn around and return the Trailer to where you picked it up, It's a illegal over weight load..Don't risk a ticket","replyToPid":24267}
GMT+8, 2026-4-17 21:24 , Processed in 0.083595 second(s), 24 queries .
