查看: 128|回复: 6
Overweight tolerance for Virginia/North Carolina
 楼主| 发表于 2019-4-30 04:16:35 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just wondering is anyone has had experience with being overweight and dealing with scales in VA and NC? I’m around 81000 lbs gross. Not over on any axle (10 foot spread trailer) just over on gross. I have DriveWyze and may get bypassed but maybe not. Anyone have experience?","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-5-10 00:17:32 来自手机 | 显示全部楼层
662888 发表于 2019-05-09 16:13:37 Tell the lumpers to take that 1000 off. It’s easy to take off then explain an over weight ticket.
","text":"Was a flatbed load of wood joist. No scale on site. ","replyToPid":30642}
发表于 2019-4-30 04:46:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it is one piece you can permit. Overweight permit. If it is multiple pieces you cant","replyToPid":0}
发表于 2019-4-30 04:45:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Va Is ZERO tolerance.  And most states are no tolerance for over gross. Some will give you a couple hundred on a set of axles as long as you are below 80000. Sorry for the bad news ","replyToPid":0}
发表于 2019-5-8 18:47:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Whatchu doin' being ova gross?","replyToPid":0}
发表于 2019-5-10 00:13:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tell the lumpers to take that 1000 off. It’s easy to take off then explain an over weight ticket. ","replyToPid":0}
发表于 2019-5-10 00:21:13 来自手机 | 显示全部楼层
670777 发表于 2019-05-09 16:17:32 Was a flatbed load of wood joist. No scale on site.
","text":"Dangggggg. Well. I guess you could take your chances. But then again that is a biggggg ticket. ","replyToPid":30643}
GMT+8, 2026-2-14 23:13 , Processed in 0.107365 second(s), 24 queries .
