查看: 323|回复: 1
SR 20 info
 楼主| 发表于 2019-4-29 06:11:34 来自手机 | 显示全部楼层 |阅读模式
GeneralThread
canComment:
{"text":"Hi all. I’m currently southbound on I-5 near Corning and have to deliver in Cloverdale on the coast. I’ve never been there before and generally run the corridor. Does anyone have and info on SR 20 between the 5 and 101?  Grade road type etc?  I’m pulling 80k of timbers with a 48’Conestoga. \n\nThanks","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-2 00:27:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I haven’t run that stretch of asphalt for some time, but if memory serves it’s rather narrow, twisty, and has a series of grade changes that can challenge one’s breaks.  Engine / jake breaking will help on many of the downgrades, but there is usually little time to build up speed prior to hitting an upgrade section, so be prepared for some “impatient” class C drivers giving you attitude.  Nevertheless, it will get you from I-5 to US-101 in a relatively fast fashion.    ","replyToPid":0}
GMT+8, 2026-2-4 12:26 , Processed in 0.062086 second(s), 25 queries .
