查看: 445|回复: 10
Do DOT officers at rest areas and truck stops wake you up?
 楼主| 发表于 2019-4-28 02:04:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"What happens when DOT shows up at rest stops and truck stops? Can they wake you up out of the sleeper to do an inspection?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-28 03:30:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t answer the door. And make sure you put a sticker on your truck that says blue lives matter and umm 🤔 have one that has a god is love As well. So when you they try to inspect your rig they’d know they’re fu**ing with a cop supporter and a child of God.","replyToPid":0}
发表于 2019-4-28 07:51:24 来自手机 | 显示全部楼层
500185 发表于 2019-04-27 19:40:36 In some states they do if you are not parked in a legal spot. I doubt they can legally inspect you when you are off duty or in a sleeper. In Europe they can however
","text":"Glad we isn't in da EU.\nNice screen handle.","replyToPid":22770}
发表于 2019-4-28 06:01:52 来自手机 | 显示全部楼层
","text":"Fuck Europe ","replyToPid":22770}
发表于 2019-4-28 12:10:08 来自手机 | 显示全部楼层
发表于 2019-4-28 09:43:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"They are not allowed to but they will try","replyToPid":0}
发表于 2019-4-28 03:47:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"they have and I never sleep or barely stop at RA'S","replyToPid":0}
发表于 2019-4-28 03:40:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"In some states they do if you are not parked in a legal spot. I doubt they can legally inspect you when you are off duty or in a sleeper. In Europe they can however ","replyToPid":0}
发表于 2019-4-28 03:02:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never had it done to me ","replyToPid":0}
发表于 2019-4-28 22:51:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I believe if you were parked Illegally. I was parked before off to the side part a rest area, State Trooper woke me up give me a $97 Ticket, But I believe it's not legal. Your supposed to have 10 hrs of interrupted sleep. I would look it up in the  FMCSA  green book rules and regulations","replyToPid":0}
GMT+8, 2026-4-17 19:44 , Processed in 0.140511 second(s), 24 queries .
