查看: 493|回复: 20
Weekly team miles
 楼主| 发表于 2019-4-27 06:11:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"On average how many miles you getting while you team?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-7 20:56:51 来自手机 | 显示全部楼层
662888 发表于 2019-04-28 12:02:54 Yea. Cause I drive solo and in 11 hours of drive time I get 550 to 600 miles a day if I’m pedal to the floor. That’s around 4000 in a seven day period. If you getting 5500 by yourself either your still running paper logs or your an owner op who can edit your own ELD’s
","text":"I was thinking the same... must be still on paper logs 🤷🏾‍♀️ ","replyToPid":23112}
回复 支持 3 反对 2
发表于 2019-4-29 06:23:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"No Logs, pedal to the floor, team no sleep","replyToPid":23043}
回复 支持 2 反对 2
发表于 2019-4-28 20:02:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yea. Cause I drive solo and in 11 hours of drive time I get 550 to 600 miles a day if I’m pedal to the floor. That’s around 4000 in a seven day period. If you getting 5500 by yourself either your still running paper logs or your an owner op who can edit your own ELD’s","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-4-27 09:31:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can get 5500 to 6000 per week. ","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-4-29 00:57:18 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I noticed that there are not too many “team” loads on board since the pricing went down((( unless you are doing a dedicated lanes for someone....it seems like the need for faster delivery reduced since some companies started doing their own freight. 🤷🏼‍♀️"}
发表于 2019-4-28 12:44:18 来自手机 | 显示全部楼层
652149 发表于 2019-04-27 03:47:33 Truck that! I put 5300-5500 a week by myself.
","text":"How?","replyToPid":22454}
发表于 2019-4-27 11:47:33 来自手机 | 显示全部楼层
662888 发表于 2019-04-27 01:31:53 You can get 5500 to 6000 per week.
","text":"Truck that! I put 5300-5500 a week by myself.  ","replyToPid":22365}
发表于 2019-4-27 11:47:13 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
发表于 2019-5-8 07:00:38 来自手机 | 显示全部楼层
","text":"BS","replyToPid":22454}
发表于 2019-5-8 07:01:15 来自手机 | 显示全部楼层
","text":"exactly","replyToPid":23112}
发表于 2019-4-29 06:50:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Team drivin' - Mostly drop & hoox rite?","replyToPid":0}
发表于 2019-5-2 12:27:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"iv done 9000 miles","replyToPid":0}
GMT+8, 2026-4-16 10:09 , Processed in 0.146995 second(s), 24 queries .
