查看: 305|回复: 7
Idling
 楼主| 发表于 2019-4-26 13:50:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello everybody i got a cascadia 2020 model.theres no comfort mode option.can anyone help me how to idle it.raised rpm and pull trailer brake only but nothing worked.thanks","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-27 02:52:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't idle, it's bad for the environment. roll down the window, take off your clothes, easy breezy.","replyToPid":0}
回复 支持 0 反对 3
发表于 2019-4-26 14:00:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"probably have to set it up at the dealer","replyToPid":0}
发表于 2019-4-26 16:11:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"hitting Cruise on and set increase doesn't work. If it dont Your company has set the parameters on the computer","replyToPid":0}
发表于 2019-4-26 16:11:36 来自手机 | 显示全部楼层
631628 发表于 2019-04-26 06:00:21 probably have to set it up at the dealer
","text":"good","replyToPid":21665}
发表于 2019-4-28 06:20:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I can help you with that bro. Let me know how if you still need help.","replyToPid":0}
发表于 2019-4-28 20:27:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it’s set to shut down between certain temps, unplug the air temp sensor by the radar, but plug it in before you roll. ","replyToPid":0}
 楼主| 发表于 2019-4-30 03:36:54 来自手机 | 显示全部楼层
333979 发表于 2019-04-27 22:20:25 I can help you with that bro. Let me know how if you still need help.
","text":"Hnji bro still need help","replyToPid":22839}
GMT+8, 2026-4-17 23:06 , Processed in 0.104774 second(s), 24 queries .
