查看: 202|回复: 10
low oil pressure high engine temperature
 楼主| 发表于 2019-4-26 09:18:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"I recently notice my oil pressure is going down to 25 psi and engine oil is staying hot above 200  but when its cold everything is fine. I have a 2010 cummins isx egr is deleted  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-26 11:13:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t laugh, but that could be an injector leaking diesel into the oil and making it thin. If that is the case it will run hot with low oil pressure... happened to my old truck. Change the oil and see if that helps. 🤷‍♂️","replyToPid":0}
发表于 2019-4-26 11:08:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"It could be due for an oil change","replyToPid":0}
发表于 2019-4-26 13:46:18 来自手机 | 显示全部楼层
发表于 2019-4-26 09:41:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Engine oil runs a lil warm on the isx motors. Mine does the same thing. No need to worry ","replyToPid":0}
发表于 2019-4-26 09:53:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"psi at 25, that's very low. check to make sure our level is correct and with a lighter, burn it to see if it burns easily. could be foaming if overfilled which can lead to low psi, or could be mixed with diesel leaking and making it lose viscosity.","replyToPid":0}
发表于 2019-4-26 09:56:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Was it windy when you noticed?","replyToPid":0}
 楼主| 发表于 2019-4-26 11:40:58 来自手机 | 显示全部楼层
651983 发表于 2019-04-26 03:13:30 Don’t laugh, but that could be an injector leaking diesel into the oil and making it thin. If that is the case it will run hot with low oil pressure... happened to my old truck. Change the oil and see if that helps. 🤷‍♂️
","text":"How can i check to see if its mixing diesel ?","replyToPid":21560}
 楼主| 发表于 2019-4-26 11:41:30 来自手机 | 显示全部楼层
672031 发表于 2019-04-26 01:56:41 Was it windy when you noticed?
","text":"No normal day","replyToPid":21513}
发表于 2019-4-26 16:42:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"ISX are notorious for oil pumps going out dont play with it that low of Psi. catastrophic failure will follow. like the other's stated could have something wrong in the head a Oring etc..","replyToPid":0}
GMT+8, 2026-4-17 08:05 , Processed in 0.090235 second(s), 24 queries .
