查看: 967|回复: 55
I just got my CDL.. what’s a good starter company??
 楼主| 发表于 2019-4-26 08:19:08 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-4-27 03:33:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Werner. I’m team driving with my husband. Werner has about 10% of women drivers (national 6%)","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-4-26 09:45:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not Swift.","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-4-26 11:17:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check out Maverick and TMC if you’re willing to do flatbed... that’s where the money is 👍 ","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-4-28 22:38:14 来自手机 | 显示全部楼层
658879 发表于 2019-04-27 18:15:55 Yes this is true but each run s independently of the others. Everybody thinks that because they are technically owned by the same corporation that they are all the same. At any rate you may not like them and in point of fact I don't like at least one of them. However I never speak ill of a company until I know first hand or have some personal experience with the company to decide if they are bad or not. If you have had some bad experience with all or some of them then I respect your opinion.
","text":"You work for Knight so your respect of my  opinion doesn't matter to me, I have worked for the Mega carriers, They pay you ridiculously low rates, Govern their trucks at 58-65 mph which limits the miles you can run per shift, Then they pay Practical miles not Odometer actual miles so if you drive free miles so they steal wages, So you keep on driving free miles and make chump change. If companies are bought out, Or merge they are not independent....","replyToPid":22731}
回复 支持 0 反对 3
发表于 2019-4-28 02:15:55 来自手机 | 显示全部楼层
505487 发表于 2019-04-26 23:17:59 Knight, Swift, And Central are All Sister companies ( same owners)
","text":"Yes this is true but each run s independently of the others. Everybody thinks that because they are technically owned by the same corporation that they are all the same. At any rate you may not like them and in point of fact I don't like at least one of them. However I never speak ill of a company until I know first hand or have some personal experience with the company to decide if they are bad or not. If you have had some bad experience with all or some of them then I respect your opinion.","replyToPid":22311}
发表于 2019-4-26 13:42:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Werner ","replyToPid":0}
发表于 2019-4-27 02:06:54 来自手机 | 显示全部楼层
发表于 2019-4-26 10:27:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try and stay away from the big ones they will Chew you up and burn you out. For nothing ","replyToPid":0}
发表于 2019-4-26 10:05:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"In your area maybe Knight Transportation. I guess it all boils down to what your looking for","replyToPid":0}
发表于 2019-4-26 09:57:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Amazon. The pay good. You never have to move your tandems due to over weight and most likely there’s a dedicated regional route in your area. And it will never slow down","replyToPid":0}
发表于 2019-4-26 08:34:11 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Too bad you do not live in NC but the company I work for is a great company to Start with.  East West in fletcher NC. Look them up. It’s a small family owned company. "}
发表于 2019-4-26 08:36:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Terminals mite B nearby. \nWhat state U's in?","replyToPid":0}
发表于 2019-4-26 08:37:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hogan","replyToPid":0}
发表于 2019-4-26 08:38:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hogan has Regional,local, & OTR whatever you want, and they will hire rookies 😀 good luck driver aim high","replyToPid":0}
发表于 2019-4-26 09:50:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maverick is the best around Arkansas great pay and very good all around company","replyToPid":0}
GMT+8, 2026-4-17 12:53 , Processed in 0.158922 second(s), 25 queries .
