查看: 176|回复: 4
How many hours per week to drive 2700 miles?
 楼主| 发表于 2019-4-26 01:36:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"Currently looking at a home weekly team driving job. According to the company, each run would cover 5400 miles per week, so about 2700 miles per driver. They also say home weekly. I come up with 54 hours per week driving assuming an average speed Of 50 mph. Is my computation correct?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-26 06:08:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thats going to be hard to meet tho","replyToPid":0}
发表于 2019-4-26 02:08:21 来自手机 | 显示全部楼层
发表于 2019-4-26 07:08:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Install PrePass to keep on goin'.","replyToPid":0}
发表于 2019-4-27 04:47:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is a safe way, But the depends what direction you are traveling for example West coast regional the  speed limit is between 55-60 mph and alot of Mountains, Traveling West Coast to East Coast as soon as you get out of the Weat Coast States the speed limit jumps to 65 to 75 in some place like just pass El Paso TX it 80 mph so depending on what speed you your truck is governed  for example some of the bigger carriers govern their trucks at 62 mph so if you run hard close  to 11 hrs. a shift you should get at least 600+ miles per shift ea. so 2700 miles is only 387 miles each per day  which is not much. So no you both should not have any problems meeting your 2700 miles per week. hope this helps","replyToPid":0}
GMT+8, 2026-4-17 21:23 , Processed in 0.075317 second(s), 24 queries .
