查看: 170|回复: 3
Iowa / MO I29 derours
 楼主| 发表于 2019-4-24 18:31:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"What detours are you using to bypass the section of I29 that is closed in Iowa?  35 to 80?  \n\nFuel stops and rest stops?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-24 23:22:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"75 from Kansas to Omaha","replyToPid":0}
发表于 2019-4-24 23:41:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on where you’re going. From Kansas City to Omaha for example take the I-29N to the I-229 to St Joseph for the US36 to the US75 north. They’re hole in the wall stops though. There’s a Walmart in Nebraska City you can park at. \nFrom Omaha to Sioux Falls,SD still take US75 to the US30 to get you back in I-29\nFrom the west, the US81 in York and that goes all the way up to I-90 and there’s a Love’s in Norfolk along the way.\nUS77N from Lincoln to Sioux City works too. \nHope any of this helps","replyToPid":0}
发表于 2019-4-24 23:45:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I-35 detour is ridiculous. ","replyToPid":0}
GMT+8, 2026-4-15 12:09 , Processed in 0.079552 second(s), 23 queries .
