查看: 268|回复: 8
Is it worth it?
 楼主| 发表于 2019-4-24 10:15:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Question. Is it possible to make good money running e logs if your an O/O with his own trailer","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-4-24 21:16:50 来自手机 | 显示全部楼层
649177 发表于 2019-04-24 09:57:38 If you run Elog ??? Son, we all have to run Elog
","text":"Incorrect ","replyToPid":19993}
发表于 2019-4-25 08:13:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I get paid mileage as a rule except we have a few lanes that we consider hourly, anything running through the Chicago corridor is one of them so bring it up with your boss and tell him you want to meet a minimum should your mileage pay fall below a certain hourly requirement","replyToPid":0}
发表于 2019-4-24 17:57:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you run Elog ??? Son, we all have to run Elog ","replyToPid":0}
发表于 2019-4-24 11:34:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"absolutely ","replyToPid":0}
 楼主| 发表于 2019-4-24 12:22:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can u guys elaborate a little please. For example passing through large cities like Chicago. It just kills your available hours and you don’t make much time. Paper logs I could just go off duty for part of that time to “ help out” ","replyToPid":0}
发表于 2019-4-24 14:26:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"who isn't on elogs?","replyToPid":0}
发表于 2019-4-24 17:18:42 来自手机 | 显示全部楼层
 楼主| 发表于 2019-4-24 21:16:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Canada and Alaska ","replyToPid":19968}
GMT+8, 2026-4-17 08:05 , Processed in 0.084150 second(s), 24 queries .
