查看: 177|回复: 9
Steering Wheel have to much play. Need answers
 楼主| 发表于 2019-4-23 01:46:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"I think my steering wheel might need to be tightened up? too much loose play in it before it responds?\nI'm not a mechanic or anything.. is this a factor that needs adjusted sometime? How about for DOT inspections?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-23 01:53:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"for your protection and everyone else atound you I advise you to go get her looked at by a real diesel mechanic, not a TA or any truck stop shop. I made my mistake of doing that and pulled out the bay with 3 engine faults. Those guys are only good for tires and mud flaps.","replyToPid":0}
发表于 2019-4-23 03:28:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"You CAN be put out of service for too much play in the steering wheel. A technician can adjust out some of the play, but if it’s too bad you may need a new steering gearbox, and/or possibly other steering system components. \n\nLike the drivers above me, I highly recommend that you visit a specialized mechanic or your truck dealership!","replyToPid":0}
发表于 2019-4-23 02:28:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always. As a general reule. Have it checked.","replyToPid":0}
发表于 2019-4-23 03:38:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always have it checked. Its not just your life its the life of everyone on the road. precaution is better than cure.","replyToPid":0}
发表于 2019-4-23 03:57:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its an easy question. you can asnwer it on your own","replyToPid":0}
发表于 2019-4-23 07:08:45 来自手机 | 显示全部楼层
612939 发表于 2019-04-22 19:57:13 Its an easy question. you can asnwer it on your own
","text":"someone is getting testy.","replyToPid":18700}
发表于 2019-4-23 16:10:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"pop Horn cap off look inside see if those bolts are loose. work your way down to linkage to gearbox. truck off twisting with hand  see play before or in gear box. then box to tie rods and  king pins.","replyToPid":0}
发表于 2019-4-23 22:14:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"When in doubt have a Service Technician check it out, In my opinion most trucks have some play in the steering.","replyToPid":0}
发表于 2019-4-24 01:28:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Drag link, Pitman arm, kingpin, gear box just some things to have checked out and alignment "}
GMT+8, 2026-4-17 16:38 , Processed in 0.070745 second(s), 25 queries .
