查看: 402|回复: 20
How do you gain shower points during training?
 楼主| 发表于 2019-4-22 22:47:27 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-4-23 11:59:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who fuel whose card will be used, thats what i had with my trainer, your trainer is just a selfish ahole.","replyToPid":0}
发表于 2019-4-23 08:48:11 来自手机 | 显示全部楼层
{"replyToPid":18616,"replyTo":"
655703 发表于 2019-04-22 17:52:13 He's not letting me gain shower points....\"We\" use his card (only) for fueling.
","text":"Your trainer is a jerk. My trainer would pump 50 gallons for me and then he’d hang up the pump and call our company for another approval and he would use his card. I would also use the accumulated points for food discounts "}
发表于 2019-4-23 01:56:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Then when he takes a shower he needs to request a team shower so you can get one too, it still only uses one of his shower credits","replyToPid":0}
发表于 2019-4-23 03:52:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have my student fill reefer. Your trainer can do team showers. Don't see why he isn't doing that.","replyToPid":0}
发表于 2019-4-23 00:56:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I I use the loves app my fuel card is attached to the account just set it up and when you pull up just open your app it will find the loves you are sitting at. Then scroll to pay for fuel and it asks for truck number trailer number then “next...”. Put the pump number and follow instructions it will turn pump on for you. Also I don’t know if you know this but if you are driving you get to fuel not the trainer! It goes on your points not his. But he should get a team shower it is same as one shower and you get to have your own shower separate from his. He should know this already use his points for showers save yours!","replyToPid":0}
发表于 2019-4-22 23:00:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a rewards card and use it when you fuel or ask how many gallons you need to pump to get a free shower","replyToPid":0}
 楼主| 发表于 2019-4-23 01:52:13 来自手机 | 显示全部楼层
632464 发表于 2019-04-22 16:56:13 I I use the loves app my fuel card is attached to the account just set it up and when you pull up just open your app it will find the loves you are sitting at. Then scroll to pay for fuel and it asks for truck number trailer number then “next...”. Put the pump number and follow instructions it will turn pump on for you. Also I don’t know if you know this but if you are driving you get to fuel not the trainer! It goes on your points not his. But he should get a team shower it is same as one shower and you get to have your own shower separate from his. He should know this already use his points for showers save yours!
","text":"He's not letting me gain shower points....\"We\" use his card (only) for fueling.","replyToPid":18576}
发表于 2019-4-23 16:14:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get your own cards and Trainers know they have codriver showers they have to give you.","replyToPid":0}
发表于 2019-4-27 06:45:18 来自手机 | 显示全部楼层
发表于 2019-4-23 22:01:28 来自手机 | 显示全部楼层
420570 发表于 2019-04-23 03:59:32 Who fuel whose card will be used, thats what i had with my trainer, your trainer is just a selfish ahole.
","text":"Get your own card, Tell your Trainer if he wants the points you will use his fuel card, He will get in trouble with the company due to he is off duty, Tell him if you are using your fuel card you are using your rewards card, Don't let thief to steal your points. 🖕 him, Or tell him you'll get a new trainer, That would be on him, Also don't ever drive any hours on his clock.","replyToPid":19261}
发表于 2019-4-23 00:31:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a loves or pilot fuel rewards card.. they will revise hour rewards card with y in store or use  the store kiosk...","replyToPid":0}
 楼主| 发表于 2019-4-23 01:52:36 来自手机 | 显示全部楼层
659854 发表于 2019-04-22 15:00:43 Get a rewards card and use it when you fuel or ask how many gallons you need to pump to get a free shower
","text":"Thanks","replyToPid":18552}
 楼主| 发表于 2019-4-23 01:52:47 来自手机 | 显示全部楼层
499247 发表于 2019-04-22 16:31:47 Get a loves or pilot fuel rewards card.. they will revise hour rewards card with y in store or use  the store kiosk...
","text":"Thanks","replyToPid":18565}
GMT+8, 2026-4-18 13:58 , Processed in 0.095280 second(s), 24 queries .
