查看: 175|回复: 3
Trailer Air Skirt Mounts Failing
 楼主| 发表于 2019-4-20 21:31:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Today I was cruising across Kansas. In the middle of passing a Swift truck when the front passenger side of my trailer skirt peeled out. Scared the hell out of the Swift driver. Anyway I pulled off and used self tapers to fix it back to the trailer temporarily. A few of the fiberglass mounts that go from the center of the trailer to skirt are broke. \nAnyone in the Denver, Colorado area happen to have or know of a welder that could make some steel brackets. It is a company trailer but they will pay to have it fixed. Saves us from getting in trouble with California. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1526.0,\"name\":\"\",\"url\":\"\",\"width\":2268.0}]","canComment":true}
发表于 2019-4-21 06:04:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"U sure it wasn't the Swift driver's voodoo?","replyToPid":0}
发表于 2019-4-21 03:03:45 来自手机 | 显示全部楼层
{"replyTo":"","text":" If they have a good mechanic at TA, they have a welder there. That’s if they have a good mechanic LOL. ","replyToPid":0}
 楼主| 发表于 2019-4-24 04:25:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ended up finding a shop in Denver that was open all weekend. They took some 1/4in flat bar steel. Bent it to match the old fiberglass mounts. Now it doesn't even wiggle in a crosswind.","replyToPid":0}
GMT+8, 2026-4-17 08:05 , Processed in 0.069456 second(s), 24 queries .
