查看: 84|回复: 1
Truckers Path needs a forum for feedback.
 楼主| 发表于 2019-4-19 15:18:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"My free trial runs out in another 2 weeks but I will not be paying for this app yet. Several things need to be corrected like:\n\n1 while in navigation mode, you can not zoom out so you're seeing more than just the 1/4 to 1/2 mile in front of you while the app keeps you centered.\n\n2 While in navigation mode, you can not see way points like fuel stops or weigh stations. Zoom out, see where you are, check parking or open/closed weigh stations, re-center again. too much fiddling with the app while driving.\n\n3 While in navigation mode, the ability to add/remove/change  waypoints.  You literally have to exit navigation to make changes.\n\n4 ERROR finding address. close the app, reopen it, back to normal.\n\n5 Turning off the **** speed warning. every time start a new navigation you have to turn it off again. The option to turn it off once and for all!\n\n6 An option to Avoid U turns!\n\n7 An option to avoid toll roads!\n\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-22 01:53:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"there's navigation mode?","replyToPid":0}
GMT+8, 2026-2-4 14:14 , Processed in 0.050690 second(s), 24 queries .
