查看: 707|回复: 13
Dash Cam
 楼主| 发表于 2019-4-18 19:18:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi, Which is a good dash cam with gps tracker, wifi connectivity and good in low light.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-20 22:16:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run a Rexing V3 with the gps add-on and a 64 gig memory card. On Amazon you can get everything for under $200. One suggestion though, I don't run it in 4k, it's to choppy. I keep it at 1080 and it's does a really good job. ","replyToPid":0}
 楼主| 发表于 2019-5-20 01:22:53 来自手机 | 显示全部楼层
505487 发表于 2019-05-19 02:45:36 I first bought all thre rand mcnally's from $99-$199 they sucked they kept freezing up, Then I bought the Garmin 45 and have not had 1 problem it came with everything it needs memory card I paid like $145 plus 3 yrs. warrente on it. Hope it helps good luck.
","text":"👍🏻👍🏻","replyToPid":37867}
发表于 2019-4-18 22:49:03 来自手机 | 显示全部楼层
662769 发表于 2019-04-18 14:32:54 I was wondering if those were good for dash cams.
","text":"They is,\nNo GPS on 'em though.\n\nHero 7 is the latest & greatest,\nwith anti-shake stability. \n\n$350 on FeeBay, But It Now.","replyToPid":16143}
发表于 2019-4-18 22:20:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hero 5 Black for me.","replyToPid":16087}
发表于 2019-5-19 10:45:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I first bought all thre rand mcnally's from $99-$199 they sucked they kept freezing up, Then I bought the Garmin 45 and have not had 1 problem it came with everything it needs memory card I paid like $145 plus 3 yrs. warrente on it. Hope it helps good luck.","replyToPid":0}
发表于 2020-1-1 12:25:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"rand McNally's 500. I love it! connects to my phone to download the footage in HD by wifi and the app","replyToPid":0}
发表于 2019-11-11 04:58:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"70mai Dash Cam Pro...you will not be disappointed and under $80.","replyToPid":0}
发表于 2019-4-18 22:32:54 来自手机 | 显示全部楼层
发表于 2019-4-18 20:10:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"GoPro","replyToPid":0}
发表于 2019-4-18 19:49:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin 55 ! To my knowledge! 👌🏻","replyToPid":0}
 楼主| 发表于 2019-4-19 02:13:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi All, thanks for the suggestion. I tried to get info on specs of Hero 7 , but i could not find any option of loop recording in this dash cam. Please advice . ","replyToPid":0}
GMT+8, 2026-4-17 06:24 , Processed in 2.947557 second(s), 24 queries .
