查看: 508|回复: 14
Turn Your Music/TV Down when parked. Don’t disturb other drivers. Especially at truck stops and terminals. Be an adult.
 楼主| 发表于 2019-4-18 18:29:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"International Trucking Group, white Freightliner, VIN # BLAY-1909, 4/18/19 @ around 6am at WaWa truck stop off of Hwy 130 in Burlington, NJ. You woke up several drivers including myself. I couldn’t believe how loud your music or tv was even with both our engines idling. I’ve encountered far too many drivers lately who are rude and careless. This needs to be handled. Please be an adult and be courteous to others. We all need to be well rested and safe. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-4-19 08:59:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wasn’t actually idling, I simply turned my engine on for a few minutes to see if I could drown out their incredibly loud noise, but that is a moot point that isn’t relevant to the meat of the subject matter. I’m not complaining about reasonable noise such as apu’s, engines, etc. It’s perfectly reasonable to point out when someone’s entertainment is cranked up so loud beyond the decibel levels of an idling engine, apu, or reefer that it actually booms and rattled windows and wakes up the drivers beside them. ","replyToPid":0}
回复 支持 1 反对 3
发表于 2019-4-18 22:19:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Since when do NJ got manners?","replyToPid":0}
发表于 2019-4-18 21:47:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you! This goes right along with guys leaving their headlights on when parked 🙄 I can’t tell you how many times I get woke up by loud music or a tv. ","replyToPid":0}
回复 支持 2 反对 2
 楼主| 发表于 2019-4-19 12:23:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe a little of both, now that I think it over. Ideally it would be preferable for said driver to see discussions about their behavior and course correct. Not sure if they were ignoring the knock, or if they literally couldn’t hear it. But I also thought aside from calling the company they drove for, at the very least starting a discussion that would eventually snowball into other discussions that will branch out in regards to this type of topic, encouraging drivers who aren’t already thinking about to this kind of thing to begin to. To plant a seed and watch it grow, as it were. But after revisiting this, I may just end up deleting this post altogether, as it seems to be a magnet for apposing and borderline argumentative reactions, which unfortunately isn’t productive, and wasn’t my intention. Perhaps I should have used more finesse in my wording, so as not to come across as what some may receive as sounding confrontational or angry. ","replyToPid":0}
 楼主| 发表于 2019-4-19 09:01:13 来自手机 | 显示全部楼层
662769 发表于 2019-04-18 19:09:48 How about you confront the driver at the time it's happening instead of posting his truck info and location on here like he's reading it. Now you've disturbed me. How rude.
","text":"I did try to politely reach out to them. And I’m not cyber bullying anyone here, just attempting to reach out peaceably. ","replyToPid":16322}
回复 支持 0 反对 3
发表于 2019-4-19 03:12:34 来自手机 | 显示全部楼层
发表于 2019-4-19 02:37:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"have some respect bro","replyToPid":16214}
发表于 2019-4-19 03:00:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"If one is going to complain about noise, then turn the trucks off too and turn the APU’s off. Sitting idling with loud engines is just like the tv and music. If you want to take someone else’s time of being comfortable, then yours should be taken too. Seriously though, it’s a truck stop, you knew what you got into when you started trucking. And if you didn’t, then maybe you should take yourself home and find another job ","replyToPid":0}
发表于 2019-4-19 00:33:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"how about no","replyToPid":0}
发表于 2019-4-18 22:58:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t rely on your jakes to stop at an offramp; BRAKE EARLIER! Idjits…","replyToPid":0}
发表于 2019-4-18 22:38:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air horns and Jake's too! inconsiderate Idiots!","replyToPid":0}
发表于 2019-4-19 02:59:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"If one is going to complain about noise, then turn the damn trucks off too and turn the APU’s off. Sitting idling with loud engines is just like the tv and music. If you want to take someone else’s time of being comfortable, then yours should be taken too. Seriously though, it’s a truck stop, you knew what you got into when you started trucking. And if you didn’t, then maybe you should take that *** home and find another job ","replyToPid":0}
发表于 2019-4-19 03:09:48 来自手机 | 显示全部楼层
GMT+8, 2026-4-17 18:38 , Processed in 0.099440 second(s), 25 queries .
