查看: 278|回复: 18
Steer Tire dipped out
 楼主| 发表于 2019-4-18 17:16:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a steer tire dipped  lightly in the middle from bad King pin. I replaced King and tie rod alignment done. the tire is brand new. Question is WIll it feather back even or its now a trailer spare ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-19 11:35:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trailer tire or spare bro. Your steers are your life. It’s part of the trade. Sometimes you have to bite the bullet. ","replyToPid":0}
发表于 2019-4-19 11:37:45 来自手机 | 显示全部楼层
656325 发表于 2019-04-19 03:35:51 Trailer tire or spare bro. Your steers are your life. It’s part of the trade. Sometimes you have to bite the bullet.
","text":"That means two new front  tires. You could ride on it for the mean time. Maybe 5000-10000 miles. You should be able to make your money back by then. ","replyToPid":16643}
 楼主| 发表于 2019-4-18 22:45:48 来自手机 | 显示全部楼层
657085 发表于 2019-04-18 14:42:11 I wouldn't ride on a bad steer. Replace it. Try some balance beads on the new one. Also, if it's cupped in the middle of the tread, could be shocks.
","text":"it was bad king and tie rod","replyToPid":16150}
 楼主| 发表于 2019-4-18 18:26:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hate just throwing $300 away but I dont need to give the roads any help bouncing me to death.","replyToPid":0}
发表于 2019-4-18 18:45:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"i have a kenworth  t680  2014 trying to see what type of brakes i need","replyToPid":0}
 楼主| 发表于 2019-4-18 18:48:39 来自手机 | 显示全部楼层
665803 发表于 2019-04-18 10:45:13 i have a kenworth  t680  2014 trying to see what type of brakes i need
","text":"probably eaton shoes","replyToPid":16070}
 楼主| 发表于 2019-4-18 18:50:02 来自手机 | 显示全部楼层
","text":"where are you and whos doing  them?","replyToPid":16070}
发表于 2019-4-18 18:50:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh ok thanks","replyToPid":0}
发表于 2019-4-18 22:42:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn't ride on a bad steer. Replace it. Try some balance beads on the new one. Also, if it's cupped in the middle of the tread, could be shocks.","replyToPid":0}
GMT+8, 2026-3-20 22:42 , Processed in 0.076254 second(s), 24 queries .
