查看: 678|回复: 30
Question about engine breaks.
 楼主| 发表于 2019-4-16 23:49:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have two trainers told me two different things. One told me to never use engine breaks on wet roads, the other told me that it is ok. So, which is it? I'm just confused.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-17 01:53:36 来自手机 | 显示全部楼层
586943 发表于 2019-04-16 17:14:27 I never turn mine off.... loaded, empty, bobtail, rain, dry, snow, ice..... I get in regular car and forget they don’t have jakes 😳
","text":"I do it all the time. I’ll let off the gas in my car expecting the jakes to slow me lol","replyToPid":14827}
回复 支持 6 反对 0
发表于 2019-4-17 01:07:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use jake on rain and snow but only medium or low","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-4-17 02:39:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had the engine brake put me in a median on ice, so I would not recommend using them on snowy or icy roads. they slow you down by applying reverse torque, so if the road surface is slippery you have a higher chance of breaking traction than you do with traditional brakes and abs.","replyToPid":0}
发表于 2019-4-17 04:59:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can actually use your jakes to test the road be it ice or wet. Simply turned them on, gently let off the fuel pedal. If they run normally you’re fine, if you hear them stutter or shut off completely ease back on the fuel and you on something slick. NEVER do any fast movements if you think it may be slick. ","replyToPid":0}
发表于 2019-4-17 01:54:14 来自手机 | 显示全部楼层
614165 发表于 2019-04-16 17:01:42 Just follow the first trainer. use jake breaks only on flat roads. thats my personal rule
","text":"What do you do on steep grades?","replyToPid":14816}
发表于 2019-4-17 01:31:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run mine always. And hardly ever have to replace brakes","replyToPid":0}
发表于 2019-4-17 00:02:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"It really doesn’t make that much difference on wet. Ice or snow I advise leaving them off. That’s just me.","replyToPid":0}
发表于 2019-5-9 03:33:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep in mind that the jake  /engine brake works with the compression of the engine and only slows down the drive line/tires so if on to much in ice or wet conditions it can cause you to jack knife if it locks up your drive tires so you have to use your head as to when to use them and under what weather conditions ","replyToPid":0}
发表于 2019-4-21 20:02:51 来自手机 | 显示全部楼层
","text":"bad advice is stupid. telling a new driver something stupid shows what kind of ass you are.","replyToPid":14816}
发表于 2019-4-17 21:53:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"if theres a chance the road is slippery  leave them off. because that jackknife happens so fast you can't react fast enough .","replyToPid":0}
发表于 2019-4-17 01:01:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just follow the first trainer. use jake breaks only on flat roads. thats my personal rule","replyToPid":0}
发表于 2019-4-17 01:12:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use them head round up here in ND","replyToPid":0}
发表于 2019-4-17 01:12:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use them year round up here in ND","replyToPid":0}
GMT+8, 2026-4-18 02:31 , Processed in 0.128120 second(s), 24 queries .
