查看: 197|回复: 8
Ummm... 10 yr rookie needs help... No Air!!!!
 楼主| 发表于 2019-4-12 11:38:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I’m in Sydney Nebraska at the loves... I’m having problems building air. \nI’ve idled up to 1000 rpm but don’t want to go any higher out of respect for the driver sleeping next to me, because this cat is pretty loud by today’s standards. \nI can’t build any air pressure at all. I’ve got air from the compressor to the dryer, and that’s where it stops. \nIt’s currently 26 degrees, and can’t get engine temperature above 140 because I have no air pressure to disengage the fan. I tried a bit of 70% isopropyl alcohol down the feed line and nothing! \nNot sure what to do from here to get air to my tanks...","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-12 18:19:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can also use the red bottle that you dump into your gas vehicles or deicing or antifreeze for the gas","replyToPid":0}
发表于 2019-4-12 17:04:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"also check the exhaust hole on the governor see if its back pressure bleeding out. Damn Governor will getcha","replyToPid":0}
发表于 2019-4-12 16:59:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"can you hold your thumb on the end of the compress ex line. Becareful with that antifreeze it will bleed into airvalves in your dash and  open another can of worms. if you can not hold the end with all your strength the compress seems tobe working. look at dryer check valve see if its struck open constant sneeze","replyToPid":0}
发表于 2019-4-12 15:07:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"maybe your air compressor is bad","replyToPid":0}
发表于 2019-4-12 13:09:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"most of the time loves keeps their items like airline antifreeze in their tire shop","replyToPid":0}
发表于 2019-4-12 13:09:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do the air bags raise up ?","replyToPid":0}
 楼主| 发表于 2019-4-12 12:24:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"There’s no airline antifreeze here... \nI’m not sure what an apportion valve is...","replyToPid":0}
发表于 2019-4-12 12:20:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"get airline antifreeze and pour it straight in the braided line on the compressor.  it works better than alchohol \n\nI've also pump the air down and let it build up a few time to get em thawed out .","replyToPid":0}
GMT+8, 2026-4-18 21:15 , Processed in 0.115569 second(s), 24 queries .
