查看: 137|回复: 2
Keep it safe in nd sd mn wi il
 楼主| 发表于 2019-4-12 10:31:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"as the title says!! ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1080.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
发表于 2019-5-16 08:35:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m in Cali doing Cali runs now f that I did that for long years not no more good luck to all you guys out there ","replyToPid":0}
发表于 2019-4-13 08:44:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Eastwood gets innocent people killed scumbag truck drivers you sc*m drivers are the worst on the road I guess it doesn't help that your big fat belly is pushing up against your steering wheel making it hard for you to steer you nasty stinky smelly things","replyToPid":0}
GMT+8, 2026-2-13 18:00 , Processed in 0.075643 second(s), 24 queries .
