查看: 319|回复: 8
Using cruise control when loaded. Is it ok?
 楼主| 发表于 2019-4-11 04:58:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just wondering if it is ok to use cruise control when you are loaded like 80,000 lbs?\n\n\nAny advice would help.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-11 05:03:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. Just be very cautious in bad weather.","replyToPid":0}
发表于 2019-5-10 00:02:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do NOT use in any inclement weather or steep grades. Other than that use it. ","replyToPid":0}
发表于 2019-4-11 06:56:16 来自手机 | 显示全部楼层
613077 发表于 2019-04-10 21:46:42 Everything is ok. Unless you are not driving safe.
","text":"agreed. always stay on the safe side","replyToPid":11125}
发表于 2019-4-11 05:35:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes. But still be very careful","replyToPid":0}
发表于 2019-4-11 05:46:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Everything is ok. Unless you are not driving safe.","replyToPid":0}
发表于 2019-4-11 16:27:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"as long as you're not sleeping behind the wheel","replyToPid":0}
发表于 2019-4-15 06:08:24 来自手机 | 显示全部楼层
251702 发表于 2019-04-10 21:03:38 Yes. Just be very cautious in bad weather.
","text":"and going down steep Mountains","replyToPid":11082}
发表于 2019-5-9 03:42:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Open road good weather yes use cruise .i like to kick it off when in traffic or comming into town as I like to have throttle control in traffic ","replyToPid":0}
GMT+8, 2026-4-17 23:06 , Processed in 0.172761 second(s), 24 queries .
