查看: 383|回复: 35
No correct answers please :)
 楼主| 发表于 2019-4-11 02:39:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"Let the games begin!","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":927.0,\"name\":\"127/26731142_2045207502358261_4400831119651223295_n_1554921565_1554921566.jpg\",\"url\":\"\",\"width\":927.0}]","canComment":true}
发表于 2019-4-11 11:27:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pump it to make it go up the hills. ","replyToPid":0}
发表于 2019-4-11 03:11:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"no brainer, flux capacitor kill switch","replyToPid":0}
发表于 2019-4-11 14:43:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you pump it 3 times and flash your high beams twice  a secret compartment pops out with a check for a million dollars cuz you found the winning truck","replyToPid":0}
发表于 2019-4-11 09:56:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just googled it. It turns out this 3rd pedal is built in some trucks to help truckers with restless leg syndrome. Also it can be used to exercise your left leg since you only need your right leg for accelerating and braking. “True Story...!”","replyToPid":0}
发表于 2019-4-11 07:23:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s the “OHH SHIEEET!!” brake","replyToPid":0}
发表于 2019-4-11 11:36:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Manual air pump for blinkers","replyToPid":0}
发表于 2019-4-11 03:43:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Foot rest","replyToPid":0}
发表于 2019-4-11 04:40:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Man pedal","replyToPid":0}
发表于 2019-4-23 08:29:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Wrong wrong and wrong, it’s a protection shield peddle against swift its a must have 2020 technology "}
发表于 2019-4-12 07:14:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"As funny as it is true to some.","replyToPid":11050}
发表于 2019-4-11 03:26:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Parking brake........","replyToPid":0}
发表于 2019-4-11 03:42:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wipers ! Duh 🙄 ","replyToPid":0}
发表于 2019-4-11 03:53:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Foot air horn... ","replyToPid":0}
发表于 2019-4-11 04:25:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"J brake duh.....","replyToPid":0}
发表于 2019-4-11 04:27:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"🙄🙄ignition!!!!","replyToPid":0}
发表于 2019-4-11 04:47:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unhook trailer. Lol ","replyToPid":0}
GMT+8, 2026-2-13 19:51 , Processed in 0.114529 second(s), 25 queries .
