查看: 252|回复: 7
Cutting fuel to save weight?
 楼主| 发表于 2019-4-10 02:04:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi. New here on the forum. Just want to ask if cutting back on 1000 lbs of fuel for per ton state weight permits is worth it?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-10 04:51:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Idk, but if you have to fuel every 5-6 hours i think its not worth it","replyToPid":0}
发表于 2019-4-10 06:49:30 来自手机 | 显示全部楼层
420570 发表于 2019-04-09 20:51:45 Idk, but if you have to fuel every 5-6 hours i think its not worth it
","text":"Bet planning will be the hardest part of his job now. LOL","replyToPid":10565}
发表于 2019-4-10 07:05:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"1k pounds of fuel you got jet fuel tanks strapped onto that thing?","replyToPid":0}
发表于 2019-4-10 07:05:45 来自手机 | 显示全部楼层
546477 发表于 2019-04-09 23:05:28 1k pounds of fuel you got jet fuel tanks strapped onto that thing?
","text":"HAHHAHAHAH. LOL","replyToPid":10676}
发表于 2019-4-10 07:49:09 来自手机 | 显示全部楼层
","text":"😎😂😂😂","replyToPid":10676}
发表于 2019-4-18 21:30:27 来自手机 | 显示全部楼层
","text":"300 gallons weight appx 2100 lbs","replyToPid":10676}
发表于 2019-4-18 21:33:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"If u have same route every week, and u plan ahead fuel stops, u can save some money, but not much, and u will loose time. Also dont forget to count ifta $.","replyToPid":0}
GMT+8, 2026-4-15 14:10 , Processed in 0.081452 second(s), 23 queries .
