查看: 294|回复: 9
11 Hour Violation Inquiry
 楼主| 发表于 2019-4-9 02:30:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have been hit with an 11 hour violation. How bad is it for my license?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-9 09:31:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dont worry about it. Not that big of a deal. Though, obviously its preferable to avoid anymore.","replyToPid":0}
发表于 2019-4-9 04:05:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"How much did you go over?","replyToPid":0}
发表于 2019-4-9 04:11:15 来自手机 | 显示全部楼层
614915 发表于 2019-04-08 20:05:52 How much did you go over?
","text":"This actually makes sense. Some DOT officers will let you go depending on how much you went over","replyToPid":10070}
发表于 2019-4-9 04:40:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are just over by 10 mins then most likely you'll get away with it.","replyToPid":0}
发表于 2019-4-9 07:44:03 来自手机 | 显示全部楼层
613121 发表于 2019-04-08 20:40:41 If you are just over by 10 mins then most likely you'll get away with it.
","text":"Some officers wont","replyToPid":10107}
发表于 2019-4-10 10:11:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Like dot or just the warning message on the machine? ","replyToPid":0}
发表于 2019-4-13 06:49:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"No not a big deal on your license but like they said you don’t want to make a habit of it because insurance companies do look at your cash score and that’s what you want to keep clean as possible .. I am wondering how you got the violation anyway on eld as it tells you when a violation is coming up .. Remember use your personal conveyance if needed and avoid that in the future, just document in the notes section why .. Good Luck","replyToPid":0}
发表于 2019-4-13 06:50:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"No not a big deal on your license but like they said you don’t want to make a habit of it because insurance companies do look at your csa score and that’s what you want to keep clean as possible .. I am wondering how you got the violation anyway on eld as it tells you when a violation is coming up .. Remember use your personal conveyance if needed and avoid that in the future, just document in the notes section why .. Good Luck","replyToPid":0}
发表于 2019-4-13 06:51:47 来自手机 | 显示全部楼层
659648 发表于 2019-04-12 22:50:29 No not a big deal on your license but like they said you don’t want to make a habit of it because insurance companies do look at your csa score and that’s what you want to keep clean as possible .. I am wondering how you got the violation anyway on eld as it tells you when a violation is coming up .. Remember use your personal conveyance if needed and avoid that in the future, just document in the notes section why .. Good Luck
","text":"No not a big deal on your license but like they said you don’t want to make a habit of it because insurance companies do look at your csa score and that’s what you want to keep clean as possible .. I am wondering how you got the violation anyway on eld as it tells you when a violation is coming up .. Remember use your personal conveyance if needed and avoid that in the future, just document in the notes section why .. Good Luck\nCSA score","replyToPid":12524}
GMT+8, 2026-4-17 11:37 , Processed in 0.094435 second(s), 24 queries .
