查看: 246|回复: 9
34 Hour Reset & PC Inquiry
 楼主| 发表于 2019-4-8 04:48:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does my 34 Reset begin after the ODPC is completed or can it LEGALLY begin when I start ODPC?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-8 15:37:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"personal conveyance is fine as long as you're not going in the direction of the load","replyToPid":0}
发表于 2019-4-20 02:51:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont believe what people in a forum say, go to the source \nhttps://www.fmcsa.dot.gov/regulations/hours-service/personal-conveyance","replyToPid":0}
发表于 2019-4-8 05:15:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"both are correct 😂","replyToPid":0}
发表于 2019-4-8 05:16:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"🙄🤔","replyToPid":9775}
发表于 2019-4-8 20:20:11 来自手机 | 显示全部楼层
47495 发表于 2019-04-08 07:37:06 personal conveyance is fine as long as you're not going in the direction of the load
","text":"That is true.  Otherwise, you have to go in opposite way of your load ( or empty trailer if u are with bobtail )\nI got a violation coz of that reason","replyToPid":9922}
发表于 2019-4-12 06:27:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have been told that if you are Going home and it is a long drive your 34 hr starts once the truck is stopped. I was also told that PC could not be used if a trailer is attached to the truck. Truck has to be at its un-laided weight, so that means no trailer just the truck weight. Look at your cab card it doesn’t show your empty weight with trailer it shows truck weight only. ","replyToPid":0}
发表于 2019-4-20 02:52:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol but even at that it is confusing as hell since they are constantly changing the interpretation. 😂","replyToPid":0}
发表于 2019-4-20 02:58:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you use PC it is part of your break, with Trailer or not. Usually, if you have hours you must use them. What the government says and your company can be two different things. Check with your company to find out their policy.","replyToPid":0}
发表于 2019-4-25 05:41:41 来自手机 | 显示全部楼层
610123 发表于 2019-04-19 18:51:30 dont believe what people in a forum say, go to the source \nhttps://www.fmcsa.dot.gov/regulations/hours-service/personal-conveyance
","text":"Thank you for the link 👍🏻","replyToPid":16859}
GMT+8, 2026-3-21 15:36 , Processed in 0.329470 second(s), 24 queries .
