查看: 120|回复: 7
Looking for some who can do oil change and fuel filter.
 楼主| 发表于 2019-4-8 02:48:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone know who can do oil change and fuel filter change for 2002 chevy workhorse 6.5 L diesel engine. near Springfield and Lorton location.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-8 03:19:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"nothing too it. just like the 5.3.. do it yourself","replyToPid":0}
发表于 2019-4-8 02:59:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you tried looking for a local mechanic?","replyToPid":0}
发表于 2019-4-8 03:13:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check Google sir","replyToPid":0}
 楼主| 发表于 2019-4-8 09:40:55 来自手机 | 显示全部楼层
103619 发表于 2019-04-07 19:19:22 nothing too it. just like the 5.3.. do it yourself
","text":"I have researching lot find out the location where the fuel pump located at but can't find it. I'll do the oil change by myself. ","replyToPid":9721}
 楼主| 发表于 2019-4-8 09:42:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you sir ill look into it ","replyToPid":9712}
 楼主| 发表于 2019-4-8 09:43:11 来自手机 | 显示全部楼层
613668 发表于 2019-04-07 18:59:09 Have you tried looking for a local mechanic?
","text":"Thank you sir ill look into it ","replyToPid":9701}
发表于 2019-4-8 21:18:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're looking for the lift pump. basically a fuel pump for diesel.  search 6.5 turbo lift pump.  \n\nhttps://youtu.be/CzSV6QX6mo4","replyToPid":0}
GMT+8, 2026-4-17 06:35 , Processed in 0.095462 second(s), 24 queries .
