查看: 290|回复: 11
Where do you put the antifreeze???
 楼主| 发表于 2019-4-6 20:37:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a Volvo truck and I was wondering if someone can take a photo and circle ⭕️ it for me where I put the stuff for my airlines ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-6 22:48:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"look for something that says \"oil\" and don't put it there. find \"washer fluid\" and don't put it there. next find \"power steering fluid\" and don't put it there either. hope this helps!!!","replyToPid":0}
发表于 2019-4-6 21:42:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just put some in your red air hose and then attach the red and blue ones together and release air for a while","replyToPid":0}
发表于 2019-4-6 21:42:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"In North Dakota we’d pour it down our gladhands. ","replyToPid":0}
发表于 2019-4-6 21:53:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"if the truck is frozen i put it in the air line off of the air compressor.","replyToPid":0}
发表于 2019-4-7 08:03:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are your trailer brakes locked up?","replyToPid":0}
发表于 2019-4-7 20:46:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's not even cold enough to use airline antifreeze.. you're just wasting money","replyToPid":0}
 楼主| 发表于 2019-4-7 21:42:04 来自手机 | 显示全部楼层
103619 发表于 2019-04-07 12:46:19 it's not even cold enough to use airline antifreeze.. you're just wasting money
","text":"I live in Canada 🇨🇦 ","replyToPid":9590}
 楼主| 发表于 2019-4-7 21:43:30 来自手机 | 显示全部楼层
630524 发表于 2019-04-06 13:53:50 if the truck is frozen i put it in the air line off of the air compressor.
","text":"You have a photo of a Volvo air compressor and the location where to put it?","replyToPid":9420}
 楼主| 发表于 2019-4-7 21:44:23 来自手机 | 显示全部楼层
645465 发表于 2019-04-06 13:42:15 Just put some in your red air hose and then attach the red and blue ones together and release air for a while
","text":"Okay thx that will help with trailer issues just need to figure out truck version ","replyToPid":9417}
GMT+8, 2026-4-18 12:07 , Processed in 0.109628 second(s), 24 queries .
