查看: 114|回复: 4
Fuel
 楼主| 发表于 2019-4-5 04:17:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"60 lbs is equal to how many gallons?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-5 05:43:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"7.1896 gal","replyToPid":0}
发表于 2019-4-5 05:47:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"WOAH! someones good at math here","replyToPid":8953}
发表于 2019-4-5 06:59:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's an interestingly odd number per gallon then...\nI was taught to go with 8 pounds per gallon so 7.5 gallons","replyToPid":0}
发表于 2019-4-5 07:55:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"What is the weight of a gallon of diesel fuel, and why is knowing this weight important? Fuel value and price[edit] As of 2010, the density of petroleum diesel is about 0.832 kg/L (6.943 lb/US gal), \n\nsoy based ester is around 7.1 lbs per gallon.","replyToPid":0}
GMT+8, 2026-2-4 12:37 , Processed in 0.058342 second(s), 23 queries .
