查看: 244|回复: 9
My trailer looks fat. Should I worry?
 楼主| 发表于 2019-4-4 23:13:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"Got loaded up today with bales of recycling. The trailer walls look like they are bulging outwards when you look from the outside. The shipper packed the trailer really tight. Is it something that I should be worried about?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-5 02:28:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"You are lucky its just the trailer that looks fat. I look fat ","replyToPid":0}
发表于 2019-4-4 23:27:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use to  seen them blown out when they come into the paper mill","replyToPid":0}
发表于 2019-4-4 23:49:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"unless that thing is bulging out really really bad I wouldn't worry about it veteran driver","replyToPid":0}
发表于 2019-4-5 00:17:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"what kind of trailer, plywood with aluminum skin, FRP?","replyToPid":0}
发表于 2019-4-5 02:23:46 来自手机 | 显示全部楼层
630524 发表于 2019-04-04 15:27:39 I use to  seen them blown out when they come into the paper mill
","text":"🙄😏🤐","replyToPid":8757}
发表于 2019-4-5 04:41:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"My company has contracts with a lot of tire manufacturers and our loaded trailers bulge out regularly. I wouldn’t worry too much about it as far as the walls blowing out...however if you run into DOT and they really want to be a jerk you might find yourself with a ticket.","replyToPid":0}
发表于 2019-4-5 07:01:52 来自手机 | 显示全部楼层
613009 发表于 2019-04-04 18:28:11 You are lucky its just the trailer that looks fat. I look fat
","text":"👆😕😒😞","replyToPid":8852}
发表于 2019-4-5 07:02:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"👆👆😕😒😞"}
发表于 2019-4-13 07:00:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"It is fine.  Do not worry","replyToPid":0}
GMT+8, 2026-4-17 11:37 , Processed in 0.138111 second(s), 24 queries .
