查看: 354|回复: 12
Weight
 楼主| 发表于 2019-4-3 22:00:08 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anybody can help me out with my weight? I’ve slid the plate and tandems it’s still saying my drive has too much weight!","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-4-4 03:45:25 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You’re tanks are full?\nJust drive a few miles and all is perfect.\n1 gallon diesel equals 7lbs\n\nEdit: And I think no one will write a ticket for 40 lbs over ;) "}
发表于 2019-4-5 07:06:57 来自手机 | 显示全部楼层
630603 发表于 2019-04-04 03:26:49 Should be fine. If you have a truck made after like 2000 you should have an APU which gives you the 400lbs exemption in most states. https://www.ooida.com/EducationTools/Info/weight-exemptions.asp
","text":"I actually showed this to the dot in Illinois a few years back and even with it in writing they said no go... It's not in our books so it doesn't apply.\nIn other words, they don't care about new laws written by the government, I guess.\n\nHowever, normally as long as you're not over gross and less than 34,000 on tandems and not over more than 200 or so on drives, you shouldn't be bothered in most places... Unless the officer is really needing that 💰","replyToPid":8611}
发表于 2019-4-4 05:25:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the states weight limits you might be good were you are","replyToPid":0}
发表于 2019-4-4 11:26:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should be fine. If you have a truck made after like 2000 you should have an APU which gives you the 400lbs exemption in most states. https://www.ooida.com/EducationTools/Info/weight-exemptions.asp","replyToPid":0}
 楼主| 发表于 2019-4-4 03:26:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Steer 11720\n34040\n33780","replyToPid":0}
发表于 2019-4-3 23:32:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Move your weight towards the the front ?","replyToPid":0}
发表于 2019-4-3 22:57:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"can't help you unless we know your weights,  post a picture of your scale ticket, and a profile shot of your truck so we can see where you have things set up.","replyToPid":0}
 楼主| 发表于 2019-4-4 20:15:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks drivers! Load dropped and 40lbs slid right through stations","replyToPid":0}
发表于 2019-4-5 07:57:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Taralanthir is correct I figure 100 miles equal 14 gallons or roughly 100lbs. So you would be fine in 100 miles. 50 miles equal 50 lbs. take distance divide by your mpg and then multiply by weight","replyToPid":0}
GMT+8, 2026-4-17 16:38 , Processed in 0.088577 second(s), 25 queries .
