查看: 530|回复: 15
Can I be fired for this?
 楼主| 发表于 2019-4-2 02:57:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was on my first run and had to turn around and backed into a yellow concrete poll. It bent the mud flap behind the drive tire.I didnt report it to the company yet. Could I be fired for this? ","videos":"[]","pics":"[]","canComment":true}
发表于 2019-4-2 03:41:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"First of all, you can just bend it back.  And as for new driver, companies usually forgive you for these incidents( not major moving violation or accidents).  But you will probably be forced to watch some safety videos etc to ensure you dont do it again.  ","replyToPid":0}
发表于 2019-4-2 03:40:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"They will probably just ask for a drug test. You should be alright. It’s best to report it to your company though.","replyToPid":0}
发表于 2019-4-2 10:21:47 来自手机 | 显示全部楼层
发表于 2019-4-2 04:38:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"nah you'll probably get a safety bounce 😂😂\n\njust straighten the d**n thing and keep your mouth shut","replyToPid":0}
发表于 2019-4-2 04:37:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its going to petty if they fire you because of that.","replyToPid":0}
发表于 2019-4-2 04:41:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"nope you'll get a safety bounce","replyToPid":0}
发表于 2019-4-2 03:44:04 来自手机 | 显示全部楼层
420570 发表于 2019-04-01 19:41:25 First of all, you can just bend it back.  And as for new driver, companies usually forgive you for these incidents( not major moving violation or accidents).  But you will probably be forced to watch some safety videos etc to ensure you dont do it again.
","text":"If you can bend it back and its still intact, dont even bother reporting to company, if its in bad shape, you’ll need to.  Hiding damages and lying are much serious than a minor incident ","replyToPid":7737}
发表于 2019-4-2 07:55:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use car jack to bend it back ","replyToPid":0}
发表于 2019-4-2 22:47:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"try fixing it best you can, use straps and truck power or jack to bend it back","replyToPid":0}
GMT+8, 2026-4-19 18:52 , Processed in 0.096903 second(s), 24 queries .
